JRC Carb Update? - The Jockey Journal Board
Old 09-16-2007, 04:16 PM   #1
gahi
gahi's Avatar
Default JRC Carb Update?
I'd like to hear how people are getting along with these carbs. thanks
68 BSA hardtail
71 Norton
gahi is offline   Reply With Quote
Old 09-16-2007, 10:56 PM   #2
BSAketcase
BSAketcase's Avatar
Default Re: JRC Carb Update?
theres a good write-up on them at the piled arms pub site http://piled-arms.com/jrccarb.html seems like the way to go, got the amal look without the problems
BSAketcase is offline   Reply With Quote
Old 09-17-2007, 06:21 AM   #3
GumbyChuck
love the one I put on my goose....been on almost a year now...
GumbyChuck is offline   Reply With Quote
Old 09-17-2007, 07:38 AM   #4
gahi
gahi's Avatar
thanks, I've read the article at the beezer board before. I'm looking for experiences like GumbyChuck's. My Amals are shot, and I cant deal anymore.
68 BSA hardtail
71 Norton
Old 09-17-2007, 09:27 AM   #5
GumbyChuck
Fought an amal for a long time. Bought the JRC, took it out of the box and installed it. Bike fired up and idled immediately. I did play with the jetting a bit - extra jets were sent with my kit. Works fine, last long time.
Old 09-17-2007, 11:06 AM   #6
B.M.G.
B.M.G.'s Avatar
so ive figured out that JRC and PWK are the same carb(?).
i have a PWK that i got off e-gay, it worked great out of the box! but, where can i find jet's? it seems to run rich..
anyone? ? ? ?
B.M.G. is offline   Reply With Quote
Old 09-17-2007, 04:40 PM   #7
nardi1
Send a message via AIM to nardi1 Send a message via MSN to nardi1 Send a message via Yahoo to nardi1
I love mine. Bolted it on and it started first kick and idled great. They are just Kehin flat slides with an adaptor. My CR125 has the same carb from the factory.
www.chrisbernardi.com
nardi1 is offline   Reply With Quote
Old 02-26-2010, 12:59 PM   #8
michaelg
michaelg's Avatar
Are you guys still running these? Are they holding up? I've been looking around for them online but not finding much, have they been re-branded or something? Thanks.
RAD, RAD!
michaelg is offline   Reply With Quote
Old 02-26-2010, 01:10 PM   #9
BSAketcase
BSAketcase's Avatar
only problem I've had with mine so far, is the needle valve sticking once in a awhile on one of the carbs, and pissin fuel everywhere (could just be dirt keeping it open also). But otherwise run great from start-up/idle to wide open.
Old 02-26-2010, 04:24 PM   #10
Hartz Bros
Hartz Bros's Avatar
I use them all the time, they are great, no hassle carbs.... Nice tight throttle response also... I have had a few leak out of the overflow hose but nothing major... Awsome carbs, and a good price.. Cant beat them odds...
Hartz Bros is offline   Reply With Quote
Old 02-26-2010, 04:38 PM   #11
Dragon
Dragon's Avatar
Made by 'PWK' (actually Keihin, with Keihin-numbered jets), sold by 'JRC'.
Info and jet numbers etc here -
http://victorylibrary.com/brit/jrc-c.htm#Bennett
http://victorylibrary.com/brit/jrc-2.htm
Dragon is offline   Reply With Quote
Old 02-26-2010, 06:18 PM   #12
beaverbikes
beaverbikes's Avatar
I have had a pair on an A65 for about 3 years. Easiest starting English bike I've ever known since I put em on. I think they are kinda ugly and feel cheap in your hand.......bought them when new concentrics were clear up to around $200 per. Got these for $100 each.
After putting them on, one was overflowing so I reached over and tapped the float bowl with screwdriver handle. It broke like an egg! Dealer sent me a new bowl, no problems since then. I wouldn't mind a couple more for the collection.
beaverbikes is offline   Reply With Quote
Old 02-26-2010, 06:18 PM   #13
nardi1
I've since sold the bike but I did have some problems with the float sticking too. Flooded the bike several times.
Old 08-09-2010, 07:01 PM   #14
BSAketcase
BSAketcase's Avatar
Any of you guys having issues with the intake flanges leaking? I'm getting bad intake leaks between the flange and the carb. I sealed one with some gasket sealer, then the other one started leaking, sealed that one and now the first one's leaking again.
I've read somewhere that people are getting these carbs with the flanges pre-glued, mine just has the two tiny useless set screws, no sealant or glue, maybe an early version? And have also seen them with thicker flanges.
Anybody figured out a fix for this? or even having issues? I'm ready to JB weld the flanges and be done with it.
Old 08-09-2010, 07:43 PM   #15
hillbillyhell
hillbillyhell's Avatar
Lately they come with the flange JB Welded (or some simlar epoxy) in addition to the two set screws. You probably do have an early one, as JRC stated the leakage was why they started gluing them on.
hillbillyhell is offline   Reply With Quote
Old 08-09-2010, 08:34 PM   #16
BSAketcase
BSAketcase's Avatar
alright, good to know, the JB weld's drying as I speak. Figured I'd give it a shot, not much to lose at this point
Thanks
Old 08-10-2010, 04:18 AM   #17
Rattlepopboom
Rattlepopboom's Avatar
Ive had one on a 650 single for a year or more with no problems at all starts with first kick idles great!Love it.........
Rattlepopboom is offline   Reply With Quote
