#1 |
so what do you do with a tank that has shit stuck in it? ie scuff pad and random newspaper crap.
you section it and make it a frisco to accomidate for the section you take out of it. plus fuck a buncha wassels. and untill now i havent run into anyone with a sectioned sporty. just wait youll see more. ![]() tank with 2inch strip cut out then welded in small sections to prevent warpage. used to weld that way for door handles and roof sections so i figured it would be safe. side not clean each weld before welding to existing weld. ![]() after cutting out the tunnel youll notice that the gap is larger than the top due to tunnel width being wider than section pulled out of the top. ![]() simply just grind the bottom edges off to seperate the sheets
I told the guy in the mirror he was crazy, I dont think he's listening. Fuck him. |
#2 |
![]() please note the edge before the metal lets go ![]() after knocking out the bottom with a grinder place the tank on a flat sheet to see what you have to trim to make the bottom level. ![]() notice from heat the paint peeled right off exposing primer
#3 |
using the sheet as a level surface i placed the sharpe flat and traced it around the bottom to get the extra that needed to be trimmed
![]() note excess taken off and crappy picture showing how level the bottom is
#4 |
using the same method as before trace the shape of the outside of the new tank dimesions
![]() cut out the shape desired insuring that it fits to the orginal designed for.
#5 |
weld new bottom to sides as pictured below. yet again i used the sparatic weld method that i used to avoid warping
![]() ![]() grind welds flush and visualy check for pinholes. the only reason there should be pinholes is from impuritys in the welds or a dirty weld (not exact name)
#6 |
now addressing the ferked up hole for the filler neck, i just cut a square shape out of shit i had laying around and traced it on top of the tank so i could cut out crap hole left
![]() then welding and grinding away. using the same method for the front were i had to cut out the tabs. the only difference is having to bend it manually to fit the shape of the front. ie knee or some fucks face. ![]() weld in place and grind
#7 |
![]() ![]() i had a buddy hold the tank for approximate postion and what kind tabs i wanted to make
#8 |
now for tabs, I made a centerline and got a width that was needed to weld to the bottom of the tank.
![]() tabs were simply flat stock layingaround that i drilled mounting holes in then welded to the bottom.
#9 |
finding the right petcock ment searching through ace's pressure fittings and valves for a while then finding a threaded steel tube that matched compression fittings.
simply drill a hole and angle cut your steel tubein desired direction then welding to the bottom. ![]()
#10 |
now that i have a way for fuel to exit but i need to fill it some how. being the extreme angle of the tank the neck needs to be relocated to allow for optimal fuel usage.
![]() cutting a slightly smaller hole then the filler neck insures i have material to join to. ![]() welding on a left over piec of curve from a exhaust build provides for a subtle profile from the side
#11 |
next i bondo the tank to get rid of any low spots from slight warpage and grinder marks
#12 |
now understand i had a run to the ole strip club next day and it is 0300 already so i sanded enough to make it look decent but not fine enough to hide sanding scratches.
paint provided by walmart regular black krylon fusion satin that i used to touch up a old car. high mounted bitch on a pole. enjoy fellows and remember when a dick face trys to get over on you by sending you a shitty tank way late and over priced, just hang it on a wall it will come in handy some day. ![]()
I told the guy in the mirror he was crazy, I dont think he's listening. Fuck him. Last edited by FHK13; 09-05-2007 at 02:42 PM. Reason: ferrrr |
#13 |
mucho-rake
the quest for the non leaking tank continues. kudos kenny. i have your DST tshirt brought them with me last night. but it looks like you had more important things to do. right on
#14 |
sexy
#15 |
Looks good.
I noticed the mig welder in the background. I thought migging a tank was a no-no b/c it does'nt fuse as good as tig causing pin hole leaks? Maybe I'm wrong but I swear someone posted that advice before. It would be nice to get some clarification from some of the better welders on the board, since all I have is a mig. But still looks good. I hope I did'nt rain on the parade. |
#16 |
You can MIG tanks
#17 |
awww you didnt piss in my cornflakes any. have to clean welds as much as possible. took 2 hours to plug all the pin holes properly and then pressure test.
tigs are expensive and I suck at my job so they wont give me a raise. mig away my friend seemed to work fine for me. oh except for the leak on a tab on the bottom due to not properly welding on a tab nut ole shamrox let me use his welder. so all is good.
#18 |
ti i tuesday and the TI showed up???? i love you man my job feels working me late with no extra pay will keep me here. not going to vent on that, not the place or time.
#19 |
TI_Tuesday
man that looks good. hit it next tuesday. i'm gonna be there.
#20 |
I've MIG welded a bead seating tank we have here at work. It gets filled with about 150 psi. of air then a valve is thrown to release the air and seat tire beads. The tank looks like a smallish propane tank. I haven't had a problem with leaking yet. I just make sure the metal is really clean and that the welder is set up right. I also find that lacing small figure-eights together is a more sure-fire method than just running a straight bead. I think you get better penetration, plus you're working over your weld a little so seal up any pinholes.
"Anyone, in any walk of life, who is content with mediocrity is untrue to himself...." - General George S. Patton, Jr. |
| Display Modes | |
