Go Back   The Jockey Journal Board > The Archives > Tech Archives
Old 09-01-2007, 07:01 AM   #1
brewdude
Default Tech tip. Weld a bracket and save paint.
to protect as much paint or powder from being burned away. Get a tube of tooth paste, apply 1/2" away from weld area and that will do it. Also, if you get the mint if makes the shop smell good. I used the heat sink paste for years and one day ran out. Tried the tooth paste and that is all I have used since. Lot cheaper also.
brewdude is offline   Reply With Quote
Old 09-01-2007, 07:57 AM   #2
KnuckleBuster
KnuckleBuster's Avatar
Default Re: Tech tip. So you need to weld a bracket and you want
If this works as well as you say it does, that ROCKS!
"Anyone, in any walk of life, who is content with mediocrity is untrue to himself...."
- General George S. Patton, Jr.
KnuckleBuster is offline   Reply With Quote
Old 09-01-2007, 08:50 AM   #3
bonneville bones
how many other things did you try before figuring out the toothpaste. Seems kinda like a shot in the wind. But thanx for the tip.
bonneville bones is offline   Reply With Quote
Old 09-01-2007, 09:03 AM   #4
Fab Kevin
Fab Kevin's Avatar
the toothpaste was a no-brainer for Brew. If you notice, he always looks his best. Keeping a supply of toothpaste on hand at all times insures it! Thanks for the tip, Brewdude.
"if it ain't STEEL, it ain't REAL!"
Fab Kevin is offline   Reply With Quote
Old 09-01-2007, 10:20 AM   #5
jinx13
I'll be trying that out next time. Thanks for the tip.
jinx13 is offline   Reply With Quote
Old 09-02-2007, 12:31 AM   #6
oldcro
oldcro's Avatar
interesting... very interesting. thanks. only a few days of tech week left. i'm diggin' it.
oldcro is offline   Reply With Quote
Old 09-02-2007, 09:54 AM   #7
Tman
Tman's Avatar
Good tip Steve! I assume cleanup is easier than with the heat sink stuff?
Tman is offline   Reply With Quote
Old 09-02-2007, 10:24 AM   #8
brewdude
yep, it is alot easier plus smells good also. It is a lot cheaper and always available.
Old 09-02-2007, 10:29 AM   #9
Tman
Tman's Avatar
Cool going to try it on some bike braze-ons I need to add.
Old 09-02-2007, 11:06 AM   #10
Creepinogie
Creepinogie's Avatar
When I was a kid the Group Home kids would lay a bead of toothpaste out on the window sill until it dried. Then they'd smoke it...
Creepinogie is offline   Reply With Quote
Old 09-02-2007, 11:28 AM   #11
brewdude
see, there are many uses for toothpaste
