Go Back   The Jockey Journal Board > The Archives > Tech Archives
Old 08-30-2007, 09:20 PM   #1
F.St.M.
F.St.M.'s Avatar
Default Tech offering: Evo cam in a pan 101
So I wanted to run evolution heads on my pan/generator bottom end.
Easy enough, get the cases machined for evo stud spacing and bolt the top end on!
But what about a cam? Evolution heads/valvetrains like hydraulic tappets and evolution cam grinds/profiles. However evo cams will not fit in a pan gearcase. They're longer, and have a much larger diameter outer journal. Not enough meat on the generator cam cover bushing boss to bore out either. Looks like we need a specialty cam!
Call 3-4 cam manufacturers & see who's willing to grind an evo profile onto a pan shaft blank. Only two companies will even talk to me. One says $500 - $600, the other says 100 piece minimum order. Since I dont need 100 special cams, nor do I fell like grabbing my ankles & being analy violated, I decide to do this.
An evo "cone" type cam looks like this:
I got an old lathe, so I get to cutting:
F.St.M. is offline   Reply With Quote
Old 08-30-2007, 09:26 PM   #2
F.St.M.
F.St.M.'s Avatar
Default Re: Tech offering: Evo cam in a pan 101
It's rough, so I press off the gear and make some fine cut passes:
Much nicer now:
Mark the approx desired overall length:
Old 08-30-2007, 09:33 PM   #3
F.St.M.
F.St.M.'s Avatar
With overall length marked:
I switch over to the bridgeport mill:
That big 6 flute endmill slices thru the cam like a hot butter through knife:
Back to the lathe, I chamfer the end:
Old 08-30-2007, 09:39 PM   #4
F.St.M.
F.St.M.'s Avatar
Machining is now done:
Compare overall length with an actual pan cam:
Looks like a keeper:
Well that's it, evo cam in a pan. My little tech week contribution.
P.S. It does run.
Old 08-30-2007, 10:20 PM   #5
Abe_Lugo
Abe_Lugo's Avatar
Dude,
That is cool and all with the changes, but do you still call your engine a pan?
I really do admire the effort to change the engine internally. Like those knucklehead sportster engines.
But it looks like your running a 5 speed? are you a douche?
Abe_Lugo is offline   Reply With Quote
Old 08-30-2007, 10:29 PM   #6
F.St.M.
F.St.M.'s Avatar
Originally Posted by Abe_Lugo View Post
Dude,
No, I call it an evo.
I am running a 5 speed.
I prefer to refer to myself as a vaginal cleansing.
Old 08-30-2007, 11:21 PM   #7
Abe_Lugo
Abe_Lugo's Avatar
you had me fooled for about 30 secs. show the rest of the bike.
Old 08-30-2007, 11:52 PM   #8
Jimmy the saint
Jimmy the saint's Avatar
I will trade you more Evo heads for your discarded Panheads
Jimmy the saint is offline   Reply With Quote
Old 08-31-2007, 12:48 AM   #9
chopperking
chopperking's Avatar
congrats, man. best tech article so far in my book. thanks for the great pics.
see ya
chopperking is offline   Reply With Quote
Old 08-31-2007, 01:29 AM   #10
SDJose
SDJose's Avatar
Panolution! Modifying newer parts for an old motor. I think that's fucking alright. Thanks for the pics.
SDJose is offline   Reply With Quote
Old 08-31-2007, 06:33 AM   #11
F.St.M.
F.St.M.'s Avatar
Sorry Mcgoo, but I'm stealing another of your pics of my bike:
Old 08-31-2007, 03:10 PM   #12
Abe_Lugo
Abe_Lugo's Avatar
but that's one of them evo based blocks with a panhead look, not the other way around.
Why in the fuck would I messup a panhead with some an evo top end?
I know guys for this wil generator blocks and call them shovel/pans.
I like evo, I have two. But if I had a ppanhead, I'd leave it a panhead.
I know this has to be some sort of joke anyhow, I not mad just a bit confused.
BTW it's a cool custom bike, but almost nothing original panhead about it.
F.St.M. , isn't it?
Old 08-31-2007, 03:16 PM   #13
Trent
Atomic Custom
Trent's Avatar
Send a message via MSN to Trent Send a message via Yahoo to Trent
Great tech.
Senseless.
But interesting.
I am thankful it wasnt a real Pan to start with.
Trent Schara
Atomic Custom
505-281-2520 shop
www.atomiccustom.com
Shop online!
http://atomiccustom.bigcartel.com/
"Custom parts are good only when they're cooler than factory parts. By cooler I mean have better lines, work better, etc."
Trent is offline   Reply With Quote
Old 08-31-2007, 03:28 PM   #14
F.St.M.
F.St.M.'s Avatar
F.St.M. , isn't it?
You're right Abe, This was not a complete pan engine that was bastardized.
It was a collection of used parts from a 1962 FL that were cobbled together in a set of S&S generator cases with the specific goal of mating an evo top end to it.
I never claimed it was anything else.
Only the rods, bearing cages, pinion shaft, pinion gear, breather, timer drive, and generator drive remain from the 62.
Even the 62 flywheels were traded for a pair of Truet & Osborn stroker wheels.
In the original tech article I used the term "pan" when I should have used the term "pan or pre-70 shovel type" It was just easier to type pan, I figured everyone would know what was implied. Sorry if I pissed anybody off with my sacreligious terminology.
Old 08-31-2007, 03:30 PM   #15
TurboRoadster
TurboRoadster's Avatar
TxPowderCoating.com
JJ member discounts 832-818-3905
Tim@TxPowderCoating.com
Highway HorrorS cc
TurboRoadster is offline   Reply With Quote
Old 08-31-2007, 03:33 PM   #16
Trent
Atomic Custom
Trent's Avatar
One other thing... Why the right hand shift?
Trent Schara
Atomic Custom
505-281-2520 shop
Shop online!
Old 08-31-2007, 04:27 PM   #17
F.St.M.
F.St.M.'s Avatar
Originally Posted by Trent View Post
Great tech.
Senseless.
But interesting.
I'ts not senseless to me. I aquired the 62 parts in trade for other shit I had that was of no use to me. Same goes for the blockheads.
In order for me to get a running engine together, I needed only cases and jugs w/pistons.
Besides my time/labor I have only $1600 tied up in that engine. I'ts a running 88 incher.
Old 08-31-2007, 04:31 PM   #18
F.St.M.
F.St.M.'s Avatar
Pure laziness.
After making the floorboards, floorboard mounting brakets, mastercyl perch, brake pedal, and plunger completely from stratch, I was tired.
I opted not to make a foot shift, but rather to use a lincoln C-6 automatic tranny bellcrank and a hurst stick that I had laying aroung in my garage.
Theres a hand clutch on the left bar.
Old 08-31-2007, 05:15 PM   #19
Abe_Lugo
Abe_Lugo's Avatar
Pure laziness.
Wow, thanks to the isight on the engine build now it make sense!
Abe
Old 08-31-2007, 06:44 PM   #20
Manny Fresh
my 2 cents. I think this rocks reminds me of the stories you hear about guys during WWll building rides for them selves using what was available, looks great ride the crap out of it, and know that you made it.
Someday I want to be rich. Some people get so rich they lose all respect for humanity. Thats how rich I want to be"
Manny Fresh is offline   Reply With Quote
