#1 |
I found this out by experience.
First, a 3 ohm coil for an electronic ignition will sometimes test good w/an ohmeter, but can still be bad. If you have 1 side of the coil that is firing and the other is not, or if you have one bad plug and no spares- you can take a piece of metal wire and wrap around the good plug and run it to the bad one and it will fire, assuming you have a dual fire setup. This got me home last summer (about 50 miles). Just don't touch the bare wire! Also a simple way to check plugs-remove both plugs from the head, leave the spark plug wire attatched, turn over engine while holding the plug against the head (making the ground). If you see spark that plug,wire and end of the coil are good. In bright daylight, you may have to cup the plug w/your hand to see the spark. Maybe this is all common sense for most, but still good to know. |
#2 |
common sense? yes.
something that a noob should know? also yes. if you are even SORTA new to wrenching and are riding an old bike, this is something to remember. thanks for the reminder
if it ain't broke, fix it till it is! |
#3 |
Good advice. I had exactly that problem with my 45 fitted with electronic ignition. I need to go 12 volts and get a good quality coil I guess.
#4 |
bloody electric problems... posted a thread a few days ago about a nasty on i had.
i think the most important thing when you have the electrical blues is stay calm, and USE YOUR HEAD. |
| Display Modes | |
