Go Back   The Jockey Journal Board > The Archives > Tech Archives
Old 08-30-2007, 01:07 PM   #1
rukwikenuf
rukwikenuf's Avatar
Default Tech Week attempt: neck cup tool
well, i'm not nearly as creative as some of you guys, but i didn't want to shell out big bucks on a neck cup installer
my cheap ass went to Ace Hardware, got a 3 foot section of all thread (which was way longer than i needed, but oh well) and a couple of nuts to fit the 3/4 allthread, and some big ass washers. i think that i spent about $6. i got 4 of the washers to fit the 3/4 bar, and then some bigger washers. sorry i don't remember the sizes. anyways, i got 8 of them.
stick the cups onto your neck, with the threaded rod going through, the 4 bigger washers were placed through on either end, then the 2 smaller ones, then the nuts. it was kinda noisy, but by tightening them evenly, i got the neck cups installed in about 2 min's, and didn't have to take a hammer to em! it actually worked quite well......
if it ain't broke, fix it till it is!
rukwikenuf is offline   Reply With Quote
Old 08-30-2007, 01:23 PM   #2
Ed
TI_Tuesday
Ed's Avatar
Default Re: Tech Week attempt: neck cup tool
tom had this set up. i used it to put in my cups. i then stole one of the big washers. welded the washer on the side of my frame to hold the key switch. good times, good times.
Ed is offline   Reply With Quote
Old 08-30-2007, 01:32 PM   #3
Antique Engine
Antique Engine's Avatar
A big C clamp will do it too.
-Paughco framed Sportster
-Triumph Bonneville (daily)
-Evo Sportster project in pieces
Antique Engine is offline   Reply With Quote
Old 08-30-2007, 02:34 PM   #4
boynamedsue666
boynamedsue666's Avatar
Send a message via AIM to boynamedsue666
thats a friggen good idea i never would have thought of that!. thanks for sharing
...VEGAS CREW...
He'sBonafide!!!!!
boynamedsue666 is offline   Reply With Quote
Old 08-30-2007, 02:36 PM   #5
shiftace
got an easy way to remove said cups without destroying them? I've never figured that one out.
shiftace is offline   Reply With Quote
Old 08-30-2007, 03:15 PM   #6
rookiebiatch
I just use a socket, that I don't like or that I am angry at at the moment, that is slightly larger than the cup opening and wail away with a bfh. Cups pop right out then bounce all over the shop floor. A long shitty screw driver through the opening works as well. It totally fucks the handle but it does not hurt the cups.
rookiebiatch is offline   Reply With Quote
Old 08-30-2007, 03:17 PM   #7
Antique Engine
A long brass drift and a hammer will knock them out.
Old 08-30-2007, 03:32 PM   #8
rukwikenuf
rukwikenuf's Avatar
knocking em out, i've used an old socket on a 6" extention and just tapped em out. the crappy ballbearing ones came out looking like shit, cuz i beat the piss outta em, but the good chrome ones came out perfect, with only one little ding on the inside of one, where it goes into the neck. slowly.
also, i used a shop rag and some duct tape to catch em. made a little bag similar to a crap catcher that parade horses have....
also, if you heat em up with a torch, they seem to come out even easier
Old 08-30-2007, 06:12 PM   #9
krusty the clown
krusty the clown's Avatar
a bearing race punch isn't too expensive. instead of a round tip is is more oval, it makes more contact on the race making it easier to remove.
krusty the clown is offline   Reply With Quote
Old 08-30-2007, 06:30 PM   #10
bwagner
To remove those stubborn cups, Take a piece of steel tubing that just
clears the inside of the I.D. of the cup. Cut a four or five in slot in it long
ways on a band saw, then turn it 90 degrees and cut another matching
slot to make four slots total around the circumference of the tube. Now
spread the tubing out a little on the end so that you can pull it into the
cup backwards(From the uncut side of the tubing section), then just
push it up against the cup, and tap it out. The tubing contacts at four
points on the cup and doesn't make a single mark on the cup. Also, if it slips through the I.D. of the cup you're trying to remove, simply insert something up into the expanded part of the tubing to stop it from collapsing under the force of the hammer blow, like one of those sockets and extensions mentioned in the other replies, thats what I've used when needed. The outward force of the socket will help keep it firmly on top of the cup instead of letting it slip through. Have fun, be safe
bwagner is offline   Reply With Quote
Old 08-30-2007, 06:40 PM   #11
halwade
halwade's Avatar
Send a message via Yahoo to halwade
Is that a campagnolo cup extraction punch, or are you just happy to see me? in either case, your home-made version as described above is awesome. Thanks for sharing!
HalWade
Lobo Solamente
www.ChopCult.com
halwade is offline   Reply With Quote
