Go Back   The Jockey Journal Board > The Archives > Tech Archives
Old 08-29-2007, 07:55 PM   #1
krusty the clown
krusty the clown's Avatar
Default tech week offering - Hot tank cleaning
i use an old banquet coffee pot as a hot tank for cyl's, heads and other small parts. mix up some simple green and water 50/50 and let'er get hot. it will even remove the old paint on cyl's. the best part is you can just blow them dry and paint them while their still hot.
krusty the clown is offline   Reply With Quote
Old 08-29-2007, 08:00 PM   #2
mad750
mad750's Avatar
Send a message via AIM to mad750
Default Re: tech week offering
Great tip! I've boiled up my carbs in water and lemon juice to loosen up gunk before! Anybody have other tips?! Post em'.
DEVIL'S PLAYGROUND/VC
mad750 is offline   Reply With Quote
Old 08-29-2007, 08:54 PM   #3
eric123
I use the wife's old crock pot with lemon juice. I boil the carbs for a few hours or longer and they come out really clean. The crock pot works great for cleaning other small parts too...
eric123 is offline   Reply With Quote
Old 08-29-2007, 08:58 PM   #4
1 ON 2
goes great with potatoes. Hehehe
1 ON 2 is offline   Reply With Quote
Old 08-29-2007, 09:19 PM   #5
JEB
JEB's Avatar
Here's an old one from 2005:
http://www.jockeyjournal.com/forum/showthread.php?t=350
Old books, mags and cycle parts for sale: http://www.flickr.com/photos/bellboyparts/
JEB is offline   Reply With Quote
Old 08-29-2007, 11:11 PM   #6
davegerard
My only advice on the lemon boiling shit is to get the lemon juice to a boil before you drop the carbs in. For whatever reason (I fell asleep in hish school chemistry), dropping them in the juice before it boils causes some rust issues. Also, the clearcoat generally gets stripped off the carbs, spray em down with wd-40, blot dry, and then apply clear coat to fix this.
davegerard is offline   Reply With Quote
Old 08-30-2007, 12:20 AM   #7
Tman
Tman's Avatar
I use the crockpot method for old metal architectural parts, just water and DAWN.
This coffepot deal, you mean the big nasty 12" diameter percolators? Those fuckers better be good for something 'cause they sure cant make a good cup of coffee.
Tman is offline   Reply With Quote
Old 08-30-2007, 12:31 AM   #8
Roach25681
Ive heard of this method before, but heard that it really only works good for the outside of the carbs and they still need gone through with a can of carb cleaner to be cleaned properly. Is this correct or does the boiling really clean them inside and out?
I use to paint...now I build jet airplanes. HTF
Roach25681 is offline   Reply With Quote
Old 08-30-2007, 02:34 AM   #9
sLowrider
sLowrider's Avatar
Many years ago I got some engine cases blasted - I told the fella I wanted them done with aluminium oxide and the dick went and used chilled iron. Every time I went out in the rain I got rusty alloy cases!! Since then I always use a BIG milk pail with old fashioned soap flakes. Boil them for about 20 minutes and all the gunk comes out of the pores. Gets them really clean and it leaves a more durable finish than blasting.
sLowrider is offline   Reply With Quote
Old 08-30-2007, 02:44 AM   #10
deadbeat
If you sprinkle parmesean cheese on the outside of a grilled cheese sandwhich,THEN grill it, it tastes like the bread you get at Sizzler, but better!!!
deadbeat is offline   Reply With Quote
Old 08-30-2007, 03:43 AM   #11
fenboy
fenboy's Avatar
Instead of boiling the carbs up you can also just leave them to sit in coke, it will take off all the gummy crap
fenboy is offline   Reply With Quote
Old 08-30-2007, 07:17 AM   #12
lost kiwi
I have found that most parts come up super clean in the dishwasher when she's not home
lost kiwi is offline   Reply With Quote
Old 08-30-2007, 07:38 AM   #13
FHK13
FHK13's Avatar
Send a message via AIM to FHK13
at least im not the only one with a angry wife. the best part is using the crock pot and forgetting the carbs are in there.
I told the guy in the mirror he was crazy, I dont think he's listening. Fuck him.
FHK13 is offline   Reply With Quote
Old 08-30-2007, 09:19 AM   #14
Caseman
Easy-off oven cleaner....but sometimes it will etch the metal/eat paint/burn your skin.
Caseman is offline   Reply With Quote
Old 08-30-2007, 09:24 AM   #15
scootermcrad
scootermcrad's Avatar
Coffee pot is a GREAT idea! I see crockpots at garage sales for like $4 also...
Still not switched to decaf...
Blogs are weird... here's mine!
http://scootermcrad.blogspot.com/
scootermcrad is offline   Reply With Quote
Old 08-30-2007, 12:01 PM   #16
Fredo
Good idea on the weekly tech tip post. Here's mine.
Make a simple cam cover, motor pully, whatever puller. You'll need a C-clamp and a peice of 1/8 or 1/4 plate. I used a 4 inch c-clamp from harbor freight. Cut the c-clamp so you can weld the threaded section onto the plate and use the screw part with the wobble foot as your push bar. Drill holes to match what ever you're trying to get off the motor or what ever. The pics describe this better then I can write it. Total cost about 4 bucks.....well 20 bucks if you include cost of beer.
Fredo is offline   Reply With Quote
Old 08-30-2007, 12:21 PM   #17
XsSpeed
XsSpeed's Avatar
When dissembling a springer front end, put the axle in then run a ratchet strap from the middle of the axle to the bottom trees and ratchet it down a little. Then take the top nuts off the top springs along with the top springs. Then loosen the racthet and pull the rest of it apart. You can reassemble it the same way.
Also a trick for bleeding brakes on a long springer or whatever is to run a 1/4" hose from the bleeder valve on the caliper up in the air higher than the master cylinder. Works everytime.
XsSpeed is online now   Reply With Quote
