Lake Injector info/pics.. - The Jockey Journal Board
Old 04-18-2007, 08:35 PM   #1
itusedtobeaboutchoppers
itusedtobeaboutchoppers's Avatar
Default Lake Injector info/pics..
saw an old AEE "show" Sportster recently...was restored back to "original back in the day" show specs... was running a polished/anodized single 34mm Lake injector.... havent seen many of these, never on street bikes, vintage drag only.. whats the deal? Do they need a mech. fuel pump? Is the pump cam/crank driven? Streetable? Single/multiple injectors? I think I remember Scorcher running this set-up, I believe on an Evo. Info/ pics appreciated...thanks in advance...
itusedtobeaboutchoppers is offline   Reply With Quote
Old 04-18-2007, 08:52 PM   #2
Stan66
Stan66's Avatar
Default Re: Lake Injector info/pics..
Ran one "back in the day" (1973). Piece of crap, in my estimation. Gravity feed, no fuel pump. Very simple "Let's pour gas thru metered orfice and see what happens!" circuitry. Ran fine on the top end, but idle to mid-range sucked. Prone to leaking and if you left the petcock on accidently, you filled the engine with hi-test. Not good. Here's one on the '66 before I wised up and went to a B.
Stan66 is offline   Reply With Quote
Old 04-18-2007, 10:35 PM   #3
trimixdvr
yep come home drunk, wake up and change the oil. If your looking for cool/vintage nothing beats an L
trimixdvr is offline   Reply With Quote
Old 04-18-2007, 11:30 PM   #4
raceman
raceman's Avatar
the Lake,Posa and Star are all very similar and found their way from small aircraft and onto bikes.You can see the disadvantage a float bowl might be on an airplane engine,right? l have a 28mm Posa sitting on a shelf,l bought it because it looks cool.The simplicity of design is beautiful but has serious limitations.They are fantastic for drag racing and forced induction or where space is limited but for a rider they are pretty hard core.Too hard core for you there bunky,try the stock CV Sportster carb with one of those big double scoops on it an a "who`s your daddy " sticker,hehehehehehe
life begins at 150mph
raceman is offline   Reply With Quote
Old 04-19-2007, 10:03 AM   #5
YOU bought a "fuel metering device" 'cause it looks cool?? Who'da thunk it?? Maybe you should send me that injector when you send me my friggin float bowl there; what was it... oh yeah, BUNKY...btw, I put my last "who's yer daddy" sticker on your ol' ladies ass cheek....go check it out... and send me that carb book....
Old 05-11-2007, 10:43 PM   #6
Monger
Monger's Avatar
From Custom Chopper Nov. '73 - Jack Burns's 92 inch Panhead.
It's running a set of 35mm Lake Injectors on a rare set of S&S dual carb heads. How Cool is this?
Monger is offline   Reply With Quote
Old 05-12-2007, 12:30 PM   #7
wow....that bike is the shit. Very, VERY cool... thanks for the pic.
Old 05-12-2007, 07:33 PM   #8
Monger
Monger's Avatar
Itusedtobeaboutchoppers was soo jazzed about this, thought I'd add the rest of the article. It's from Randy Smith's site.
Old 05-13-2007, 10:24 AM   #9
jbfrmca
is this kinda what your looking for?
http://www.network54.com/Forum/47852...35mm+posa+carb
jbfrmca is offline   Reply With Quote
Old 05-13-2007, 11:19 AM   #10
Originally Posted by jbfrmca View Post
yeah; woulda snatched that one; but just scored 4 Lakes... thanks for the link, though.. J
Old 11-04-2010, 10:29 PM   #11
Toomey
Cherry Pie runs a Lake.
Toomey is offline   Reply With Quote
Old 11-05-2010, 04:17 PM   #12
hdshovel82
hdshovel82's Avatar
my buddy runs a lake on his pan.loves it starts easy just have to remember to shut the gas off
hdshovel82 is offline   Reply With Quote
Old 02-09-2011, 04:44 PM   #13
brianmccrocklin
is it possible to run just one lake injector? if so what size would you need for a 48 pan
brianmccrocklin is offline   Reply With Quote
Old 02-10-2011, 08:43 PM   #14
PONY
PONY's Avatar
I worked in a shop in Orlando Fl. back in the 70's that sold Lakes for a while and I have to agree with Stan66. They were marginal at best, Great top end, hit or miss every where else. We also sold SU carbs, Del Orto (Weber) Dual Throats, Mukuni and others. At that time everyone was looking for a Performance Carb and grasping at straws. Up untill the second generation of S&S carbs (early S&S had issues.) it was a real crap shoot. Every Carb was Good at something, BUT none were good at everything. But it was a lot of fun!
PONY is offline   Reply With Quote
Old 02-10-2011, 10:03 PM   #15
Hoofhearted
Hoofhearted's Avatar
Are these any relation to the Wal Phillips "fuel injectors"?
Old 02-12-2011, 06:43 AM   #16
bdavanza
bdavanza's Avatar
I like that they have a routt cylinder in the pics. I have one ready to go on my 68 TR6 with gapless rings and forged pistons. Woo Hoo!
bdavanza is offline   Reply With Quote
Old 02-12-2011, 06:54 AM   #17
lytedrive
I HAVE A COUPLE OF POSA FUELL 30 MM
NOT FITTED THEM TO ANY THING YET,
I LIKE THE WAY IT IS MOUNTED hORIZONTAL IN ChAREEPIE
lytedrive is offline   Reply With Quote
Old 02-12-2011, 07:48 PM   #18
lytedrive
WOULD A REMOTE FLOAT BOWL,
hELP STABILISE THE fUELL ON A LAKE?
MIGHT LOOK COOL
Old 02-12-2011, 11:14 PM   #19
Tony the torch
Tony the torch's Avatar
I've done a 67 Triumph with a set of Lake's on it, after I figered out how to tune them they worked great, just don't forget to turn the gas off.
the secret was needle to slide height for running mixture and then the indexing of the "D" shaped needle for idle mixture.
and a little adjustment goes a long way with those carbs and the label "fuel injectors" was a joke, they are just bowl-less carbs.
Old 12-29-2011, 01:23 PM   #20
r50us68
I found some info on how to tune the Lake carb.
http://www.greatplainsas.com/iposa.html
the reason I found this thread and the tuning is I saw this Triumph with a set of Lake
http://orangecounty.craigslist.org/mcy/2767152455.html
r50us68 is offline   Reply With Quote
