panhead crankcase vent - The Jockey Journal Board
Old 04-09-2014, 09:15 PM   #1
Randy Burkey
Default panhead crankcase vent
I bought a bike with a Pandemonium 88" motor..seems to have good compression and doesn't smoke, runs good .. But the crankcase breather seems to blow out excessive oil.. Once the motor is operating temperature if I blip the throttle sitting still, it will put out a mist of oil on the ground.. I just have a 6" hose going toward ground?? any thoughts? Thanks, Randy..As an afterthought(edit) I'm running open belt primary and belt final drive, so venting into primary case is not an option..
Randy Burkey is offline   Reply With Quote
Old 04-09-2014, 10:03 PM   #2
leoj
leoj's Avatar
Default Re: panhead crankcase vent
Do you have a lot of miles on it yet? Does it sit for a period of time between runs?
If you haven't ridden it a lot, could be just a slightly bad checkball in the pump and there's a bit of oil build up in the case.
"Don't feel like Satan, but I am to them"
leoj is offline   Reply With Quote
Old 04-10-2014, 09:31 AM   #3
Randy Burkey
Thanks, I'll ride it for awhile and see what happens..
Old 04-10-2014, 10:27 AM   #4
servi-spoke
servi-spoke's Avatar
My 1973 shovelhead does not blow oil or smoke but seems to really pump out a lot of air. Is that ok?
The future belongs to the few still willing to get their hands dirty.
53G 57FL 58FL 71XLCH 72XLCH 73SS350 73FX 74FXE 86FXRT 40MC
servi-spoke is offline   Reply With Quote
Old 04-10-2014, 11:37 AM   #5
Randy Burkey
Would it help to put a longer hose and a breather upward on the end?? or create more problems?
Old 04-10-2014, 12:18 PM   #6
S.T.P.
S.T.P.'s Avatar
Do not put any kind of filter or other obstruction on the breather. You will regret it. The breather expells the air that is under the piston on it's downstroke, if it is restricted by a filter the air will go out elsewhere. Like the pushrod tubes or base gaskets. The more air being pushed out of that breather the better. If there is excessive oil with it then the scavenging side of the pump isn't working well or the breather timing in the cam chest needs attention.
"Mine doesn't leak, It sweats HORSEPOWER!"- chromepig13
CLUBS R 4 SEALS
S.T.P. is offline   Reply With Quote
Old 04-10-2014, 01:36 PM   #7
dan r
dan r's Avatar
I'm not up to speed on a pandawhatever engine...
does it have the normal pan type oiling system?
if so, pans had a primary chain oiler feature with the oil pumps that spewed some oil mist into the crankcase breather system.
look for a small adjustment screw and lock nut on the side of the oil pump body, turn the screw in...
dan r is offline   Reply With Quote
Old 04-10-2014, 02:58 PM   #8
Randy Burkey
I have 2 small adjustment screws on oil pump 1 comes out the center of the face towards rear of bike, and 1 comes out the side of pump towards the right of bike.. I thought I read on here that closing them completely might do damage??( top end??)
Old 04-10-2014, 11:20 PM   #9
dan r
dan r's Avatar
rear adjuster is to adjust oil flow for a rear chain oiler.
side adjuster is to adjust primary oil flow that leaks into the breather passage that gets blown onto the chain.
no way adjusting them can alter flow to the top end... they both get the oil from the return circuit anyway. if some one told you it will alter the flow to the top end, they don't understand how an oil pump works.
any chance of a pic of your pump?
