i hate kick only bikes - The Jockey Journal Board
Go Back   The Jockey Journal Board > To The Editors > Questions & Suggestions
Old 02-14-2007, 07:58 PM   #1
B.M.G.
B.M.G.'s Avatar
Default i hate kick only bikes
so here is the deal: i have a 65? triumph, bonneville bottom end,morgo big bore kit, tr6 head. i run a joe hunt mag with a tympanium and a battery eliminator. i only have a hi/lo switch for the lights and a on -off (kill) switch for the mag. this thig sucks to start!! you can kick this thing for an hour and it wont start! what can i do (change?) to ke it start easier (run better?) any help will helpmahttp://www.jockeyjournal.com/forum/a...1&d=1171504236
B.M.G. is offline   Reply With Quote
Old 02-14-2007, 08:05 PM   #2
squatch
squatch's Avatar
Default Re: i hate kick only bikes
Hey,
The Questions and Suggestions forum is to ask the forum admins to change something with the site. You will get many more responses if your repost your question to the regular Forum.
My initial thought though has to do with the Hunt mag. The have no timing advance so when you try to start the spark is perhaps too advanced. Try retarding the spark a bit and see if it starts easier. Someone else on the board will be able to tell you exactly how to do this.
Casey Clark
squatch is offline   Reply With Quote
Old 02-14-2007, 11:32 PM   #3
B.M.G.
B.M.G.'s Avatar
Sorry About That: I Think I Also Posted This Some Where Else???
Old 06-05-2007, 09:25 PM   #4
squires
squires's Avatar
do you know what the mag is timed at? It should be about 39 degrees also check the point gap which should be about .012-.015. Maybe replacing the points and condensor if you are unsure about them. Try huntmagnetos.com
squires is offline   Reply With Quote
Old 06-06-2007, 09:41 PM   #5
Dr.Frankensickle
Dr.Frankensickle's Avatar
one thing about kicker only bikes is they will make you keep it in a fine state of tune...if ya wanna ride.
Dr.Frankensickle is offline   Reply With Quote
Old 06-08-2007, 07:24 PM   #6
Jimcantchop
Jimcantchop's Avatar
If you aint kicken your chicken!
Jimcantchop is offline   Reply With Quote
Old 06-25-2007, 08:07 AM   #7
Lowlife
Lowlife is offline   Reply With Quote
HTML code is Off
