evo in 4speed frame question - The Jockey Journal Board
Old 02-08-2007, 02:37 AM   #1
skincat
Default evo in 4speed frame question
just a simple question. i searched for it but could not find. so here it is. what does it take to put an Evo motor in a 4 speed shovel frame? any help would be appreciated.
skincat is offline   Reply With Quote
Old 02-08-2007, 02:50 AM   #2
victm
victm's Avatar
Default Re: evo in 4speed frame question
From what I have seen, notch seat tube for rear head/valve cover clearance, raise top tube as evo engine is 1" taller, I believe (I am sure I will be corrected if I wrong).
victm
www.sinners-inc.com
victm is offline   Reply With Quote
Old 02-08-2007, 08:43 AM   #3
BadMonkeyMW
BadMonkeyMW's Avatar
That sounds like the basic procedure. The frame definitely has to be modified to take the taller engine.
Every time you say 'period correct', Jesus weeps.
http://badmonkeymw.tumblr.com/
BadMonkeyMW is offline   Reply With Quote
Old 02-08-2007, 09:27 AM   #4
geasy$
geasy$'s Avatar
thats about right. I had an evo stuffed in an old 4 speed frame. the problem is the clearance on the back jug...........
Support Your Local Jockey Shifters............OG
"I hope I don't poop before we get home" ........BFG
geasy$ is offline   Reply With Quote
Old 02-08-2007, 09:31 AM   #5
Danny F.
Danny F.'s Avatar
The center post has to be notched yes, but to fit the taller evo under the seat post triangle so to speek it's enough that you grind the bottom of that area flat end reweld it shut...of course this way the evo will fit, but if you ever have to take your rear valve cover off...
I did it a couple times with this method because I like the lower seat height on rigid pan-shovel frame against custom rigid evo frames...
These 2 bikes got repop pan-shovel frames wich I modified to accept the evo...
ID:	13814   Click image for larger version
Danny F. is offline   Reply With Quote
Old 02-08-2007, 05:15 PM   #6
Cromagnum
Is it easier to lower engine mounts? or does that mean tranny mounts need to be lowered too/ What if your runnin an open Primary?
Cromagnum is offline   Reply With Quote
Old 02-08-2007, 06:01 PM   #7
chicoman7
Send a message via AIM to chicoman7
I ran an evo in an old rigid santee frame with a open primary. Just had to notch the down tube and take a little meat out of the backbone and use a shoe horn.
Of all the women that have been in my life i love my bike the best
chicoman7 is offline   Reply With Quote
