1969 Shovelhead crankcase breather fitting? - The Jockey Journal Board
Old 05-14-2013, 04:09 PM   #1
cruzin2dwc
Question 1969 Shovelhead crankcase breather fitting?
My 1969 Shovelhead is missing the fitting for the crankcase breather. Located to the left of the oil pump. When looking at the motor from the back. Does anyone know the size of this fitting? Or where to get one? Thank you!!
cruzin2dwc is offline   Reply With Quote
Old 05-14-2013, 04:43 PM   #2
Dragstews
Default Re: 1969 Shovelhead crankcase breather fitting?
VT No: 40-0121
OEM No: 24912-52A
Chrome breather pipe with fitting nut.
The pipe opens into a container for ventilation. Breather pipe is manufactured to meet OEM specifications for long lasting durability and performance.
Fits:
XLH 1957-1978
XLCH 1957-1978
KH 1954-1956
Old 05-14-2013, 04:53 PM   #3
cruzin2dwc
That sporty gear case vent fitting is the same as a shovelhead crankcase fitting? Just double checking before I buy this.
Originally Posted by Dragstews View Post
VT No: 40-0121
OEM No: 24912-52A
Fits:
XLH 1957-1978
XLCH 1957-1978
KH 1954-1956
Old 05-14-2013, 05:26 PM   #4
Dragstews
The fitting are the same as the early Sportster used..
That part from VT uses a steel tubing...
You can get a piece of copper that bends much easier to replace the steel....
You will need to flare the end.
Old 05-14-2013, 06:53 PM   #5
shovithead
shovithead's Avatar
1/2 inch pipe, flare fitting for 3/8ths tubing. Available at any hardware store.
72 Chevy C30 truck
73 Custom Shovel
70 XLH
69 XLH
69 XLH *project*
68 XLCH *project*
66 FLH *Daily Rider*
66 Shovel/Pan/Pan*project*
65 XLCH *project*
60 XLCH Doc Dytch*project*
51 FL *project*
42 UL*project*
Old 05-15-2013, 01:00 PM   #6
Dragstews
Home Depot is your friend...
(Ya never known what ya just may find down there..)
http://youtu.be/n55B0QUEyd8
Old 05-15-2013, 03:41 PM   #7
Sporticus
Sporticus's Avatar
It's not a pipe fitting. Learned the hard way.
Sporticus is offline   Reply With Quote
Old 05-18-2013, 05:24 PM   #8
Gordo-uk
Gordo-uk's Avatar
Are we talking this just inboard of the oil pump;
Cheers
Gordo
Gordo-uk is offline   Reply With Quote
Old 05-18-2013, 05:34 PM   #9
Dragstews
No.....
That's the suction for the primary...
He's talking about the case breather vent...
Old 05-24-2013, 05:00 PM   #10
cruzin2dwc
Thanks for the help guys!!
