I want to remove both fork legs and take the entire fork leg assemblies to shop for rebuild. I doubt if the forks have ever been removed.
I've read a lot about the special puller that's available to install the fork legs when reassembling, to properly seat in the tapered top fork clamp. But I can't find much about how to disassemble, i.e., extract them from the clamp.
The manual says there's a factory tool (not available) or use an old fork cover cap and whack it with a mallet to try to knock loose and hope for the best. I don't have an old cover and don't want to mar or damage anything in the disassembly process.
Removing the forks is relatively easy compared to installing them. Remove the front wheel, axle, fender, brake cables etc, unscrew the large fork tube nuts atop the top yoke and then loosen the pinch bolts on the lower yoke and then pull and twist each fork tube out. The tension of the spring will help to push the forks down and out. There may be a bit of corrosion or rust where the tube was held by the lower yoke, spray with PB Blast, oil, WD40 or whatever you have.
Reinstallation is much easier with the proper service tool to pull the fork up against the tension of the spring. If you do not have the proper service tool, place both tubes into the lower yoke with the axle threaded through the lower slider. Use a ratcheting compression strap around the axle up to the fork yokes (trees) to pull the fork tubes up into the top yoke, replace the top fork nuts and washers, tighten the pinch bolts on the lower yoke and then remove the strap.
If you can get a hold of an extra top nut, machine the hex part off. Tap the top of it so you can thread a bolt into it. That way you can use that bolt to pull fork tube up through the nacelle "ear" things.
Thanks for the replies. T100C fork legs successfully removed and rebuilt. Am going to fabricate an installation tool from an old fork cap, drilled for a threaded rod so I can use as a puller. That should work?
Thanks all for the advice and the pic of the fabricated installation tool. My tin ware is at the painter and once the fork covers are back we'll install the fork legs. I'll make a puller tool as in the pic out of an old fork cap.
