T140 Bonneville street tracker-kind of mix project ODDISEY - Page 10 - The Jockey Journal Board
Old 01-06-2014, 03:14 AM   #181
Daddy Boy
Default Re: T140 Bonneville street tracker-kind of mix project ODDISEY
True backyard boogie Reverb. I like your style mate.
Old 01-06-2014, 09:27 PM   #182
reverb
...hello mate, thanks. Next week I ll try to continue with the thingy; letting all these festivities behind, the work (Im a surfboard builder; this is the most busy time in the year in the South cone, as you know) and that my daily driver pre unit have problems...man, even my Bajaj (Vespa style) is leaking gas...
Old 01-07-2014, 12:37 AM   #183
Daddy Boy
Well that explains it man, lookinn at your hands I thought you were ether wearing rubber gloves, you're an albino or ....a surfboard shaper covered in powder.
Dont mind me mate, looking forward to the next chapter of your build.
Cheers
Daddy Boy
ps The sidestand is a beauty!
Old 01-07-2014, 06:23 AM   #184
reverb
...I usually wear gloves due to the greasy/oiled hands or under the nails is a no no to build boards; mostly on the glassing department...and take me about 2 days! to clean the hands
Old 03-29-2014, 07:10 PM   #185
reverb
Hello, very busy these two months to continue, only 4 times I went to work on the bike; however, I just resolved several issues that I had not so clear, like fender;reinforcements; seat, etc.
I have been building this fender from near scratch; I used an old leftover as a base and built from that.
Made it like a puzzle due to several things going on. The main idea is to hide the side brackets. These struts will hold the fender (and let a person sit there) and the detachable sissy bar. Still not welded the bungs that will serve to screw the bar.
I did these side brackets first straight then a bit bended over; finally, I bended similar to an sportster (I did not took photos about it)
-the camera is not good so there s an optic illusion about the distance from the tire. The lens show the fender too far back and too tall regarding wheel, but in reality the position looks better. The back tip of the fender finish in the same line of the rim.
--Of course all in rough state.
---you know, is so simple the fender and seat solutions if the bike will have only one seat or the fender do not need to carry a possible passenger...like 90% of the bobbers here.
Thanks for keeping the interest.
Old 03-30-2014, 02:13 AM   #186
Daddy Boy
You're a truly amazing specimen Reverb but I likes ya!
I love the guard man, really. True freestyle.
Old 04-04-2014, 08:41 PM   #187
reverb
...Hi Daddy boy, yeah freestyle because I did not had too many options but still tweaking here and there to try to finish it.
Here I did a shield for the oil tank; most secondary roads do not have asphalt here so a bit of prevention to the tank paint, due to I do not have enough space to continue the fender with the right circumference.
-A tube to reinforce the upper part of the rear frame.
I ll reinforce the swing arm too, however, I do not see it stiff enough...I accept opinions about it. May be I m accustomed to the rigid frames?
Old 04-05-2014, 03:34 AM   #188
Daddy Boy
Good move bro, triangulation equals strength.
Swing arm; I made a new axle plate and butt welded for 1 1/4" stretch.
Plugging pipe? Entirely up to you man. I would want to be confident of my welding skills.
Check this out Reverb.
http://victorylibrary.com/brit/chassis-2a.htm
Cheers
DB
Old 04-05-2014, 03:46 AM   #189
Daddy Boy
Actually after looking at your arse end again (yeah righteo), The more you strengthen the top. ie: what you are doing to triangulate the frame. If you mount that nice rigid guard well it will put less stress on the swing arm IMO.
Imagine what that SA is doing through a speedy bend and you hit a pothole with your top frame un strengthened.
Old 04-07-2014, 12:57 AM   #190
reverb
...I read that wpage few years ago; also another member talked about it in other thread that I asked about this same thing.
Photos of your swing arm weld would be good.
Old 04-07-2014, 02:53 AM   #191
Daddy Boy
Old 08-12-2015, 07:17 PM   #192
reverb
...hello, may be some of you still are interested in this thread.
Long time without updating due to: working overtime; 2 broken cameras!(infamous lens error message); I have been having extra working updating my house; you named it: electricity lines; new flooring, stone wall covering, etc; my other motorcycle had a problem so I just dismantled top end, primary etc to keep riding..
Regarding the bike, I made again several things, like the exhaust, so not to much to update.
However, an important part is that I really do not have the tools (or a skilled buddy) to finish with the rear part (mudguard that can carry a pillion + detachable small sissy bar with hidden tabs etc)
and I was and still not satisfied with the trial results.
Now I am at an stage than I do not know how to go forward (mainly for not having access to the right tools); ok, mostly I did it without the right tools but now I have tight spaces and are the finished parts so all should be correct...
Anyway, here photos toying with a modified breadbin tank and the last iteration of the exhaust (I chopped couple of new ones and made a "lip" for the cone)
Old 10-11-2015, 08:50 PM   #193
reverb
...hello,
I finished with that mudguard; is not good but I want to finish with the bike and then if I have better tooling options, etc I ll do it again, these not so perfect parts.
The mudguard has side brackets inside where I welded 3 threaded tubes per side to hold this detachable sissy bar.
When the bar is not on the bike you do not see any of these other parts, and still the fender can hold a person.
Of course is not the best to have fasteners down side but we ll see what happens. The screws are (6) 3/8 UNF thread.
As mentioned this sissy bar is detachable so I ll only use it when a big bag would be used.
The tip of the rake follows the frame rear down tube and the forks.
The rod is 9/16 mild steel.
I think there are no so many of these sissy bars for the swinging arm bikes.
Old 10-27-2015, 10:39 PM   #194
reverb
...I let that mudguard to a guy that have a TIG with the hope that with that tool and his knowledge, better than mine, performed a job that did not "moved" the tin to one side or to the other...did not happened, and Im finished with an even crappier guard.
To try to put again the thing in shape, I had to use an small jack. I do not know if in the future after couple of Suns, the fucker could shrink again...¿?
-I bought this horn from a JJ member, but did not worked; so I decided to open it and after a bit of sanding, cleaning and a dash of oil, it s perform superb.
Let these pictures, for the guys that have horns that they think are death; still you can get good life from those!
Old 01-19-2016, 07:09 PM   #195
reverb
...hello, the other day I did the brace in the swing arm as the link provided by Ourmaninshanghai,
Here s a few pictures before finished with the welding.
Old 01-25-2016, 07:26 PM   #196
reverb
...few days ago I made the license and light holder. I do not get it why all these brackets are made for the low part of the shocks; its stupid to have the lights moving up and down with the swing arm...
Old 01-26-2016, 08:32 AM   #197
Mike Britton
Mike Britton's Avatar
I agree on the tail light! It would seem to me the vibration from the swing arm alone would be enough to kill the tail light.
BTW, is there any baffling inside those mufflers? It would be interesting to hear them, they look nice! You have the stance just right. I like where you are going here.
Old 01-27-2016, 10:52 AM   #198
reverb
...hello, yes, also the vibration just killed me the license plate on my 500cc, also I lose it riding in a long trip in other country, due to freeway speed, so I made this one stronger.
-no mufflers...yet. I ll try this way but if the sound is too annoying I ll put something. I see that the 750ccs do not sound to cool as the others without the silencers..
Thanks
Old 01-27-2016, 05:23 PM   #199
Lester
Lester's Avatar
Fab from scratch, I like it!
Keeping going, looks great!
Lester
'62 DuoGlide Mine for 23yrs
'62 Triumph T-Bird in boxes
'63 BSA Lightning Café Racer
'75 BMW R90 stock
'83 BMW R100 commuter
'70s Jawa speedway DT500
'80 couple og Jap bikes too
Old 01-30-2016, 06:34 PM   #200
reverb
...Lester, thanks; it s a slow building due to I do not have the right tools and the right knowledge sometimes.
Here the nuts for the rear spindle; two for the drum brake lever, for the torque stay and the other is for the brake lever.
SS; not so perfect but would play...
