'62 Chop, 4th Rebuild in 42 years..... - Page 14 - The Jockey Journal Board
Old 10-21-2016, 12:39 PM   #261
2Loose
2Loose's Avatar
Yeah, yer prolly right,
It's prolly plenty solid this way,
but I still wanna think on it a bit...
Seen too many half azz repairs out onna road cuzz
stuff vibrated off, better to get it now in the shop...
Willy
Old 10-22-2016, 11:46 PM   #262
2Loose
2Loose's Avatar
I'm runnin' hard with a whole buncha stuff going on, so here's a few pix...
Got the rear brakes done...
And started workin' on the exhaust...
There's a bunch more pix on my home page HERE if yer interested...
Aloha,
Willy
Old 10-30-2016, 02:05 PM   #263
2Loose
2Loose's Avatar
Managed to find a couple of hours to go work on this project a bit....
Maybe I should just shorten that front pipe and just weld the muffler on here ??
Nawww, I gotta try to do this "right"...
Whatever that is....
Fabricated some brackets, and strapped them to the bottom
frame rail, and tried to hang the mufflers so minimal fab
work is required on the exhaust piping to get them done....
Considering sliding this muffler back a little and adding a little more pipe,
but it's pretty close to where I want it....
Measured the angle of the front muffler/frame here,
6 degrees, want to make the rear muffler the same....
That's going to take a little more fab work to get it right....
I hope I'm really up for this....
When I pulled the offset drive Morris Mag off the shelf,
where it was waiting for another project, I needed to replace it,
so I ordered another one for that other project....
Even though it was well packed in styrofoam and
well packaged, the Post Office must have used it
as a football, the cap was busted in a bunch of pieces!
It was covered by Post Office insurance, let's see if that
really works, or if it's just another Gov't scam !!
Aloha for now,
Willy
Old 10-31-2016, 02:27 PM   #264
2Loose
2Loose's Avatar
Found a couple of hours to work on the '62:
Still working on brakes and exhaust...
Found these SS cllips online that fit the 3/16"
brake lines....
They needed a bit of reshaping to fit the frame tubes....
Just a bit....
Looks good to me....
Did 7 of them, should be enough for this job...
Now to drill and tap the frame tubes for these clips...
Found these in my scrap pile, not sure what they are from,
but I cut them up and reshaped them to fit the frame tubes
to hang the mufflers...
Got them located and welded them on....
Bolted up the mufflers, it looks good to go....
Now to cut and weld in some 1-3/4" pipe as needed....
Will use blacki hi-temp paint on the pipes,
but will leave the mufflers as is....
More later,
Willy
Old 11-01-2016, 12:36 PM   #265
2Loose
2Loose's Avatar
Had a little time yesterday, and the 3/16" brake line clamps came with 10-32 ss screws, so dug out the 10-32 taps and the #21 drill bit and mounted 'em...
3 on each side looks good, and the fit seems good too....
More later...
Willy
Old 11-01-2016, 10:55 PM   #266
2Loose
2Loose's Avatar
Cut and fitted some pieces of exhaust pipe....
Now to weld them up and paint them...
More HERE...
Aloha,
Willy
Old 11-02-2016, 10:17 AM   #267
Brian B
Looking good!!
Brian B is offline   Reply With Quote
Old 11-02-2016, 11:51 AM   #268
Just Passin' Thru...
yep! ...looks good!
Old 11-05-2016, 02:26 PM   #269
2Loose
2Loose's Avatar
Welded up the pipes with my mig..
It's an older Millermatic 251, but it still works well...
My hand not as steady these days as it used to be,
but the welds are solid, didn't blow through anywhere,
and I can dress up the welds a bit before I paint the pipes...
More Later....
Aloha,
Willy
Old 11-07-2016, 12:04 PM   #270
2Loose
2Loose's Avatar
Dressed up the welds a bit on the front pipe,
Then ran an 80 grit roll over the surface to rough it
up where the hi temp paint will go....
I'll smooth out the welds a bit more, then
will paint them, but might leave the mufflers shiny....
at least for now....
Still thinking about that....
Old 11-08-2016, 12:16 AM   #271
JAWS
JAWS's Avatar
Yup. Shiny muffs. Wanna tig those welds? Got some extras that we could cut up and tig with stainless. Keep it shiny.
ROLLING DEATH
Old 11-14-2016, 07:11 PM   #272
2Loose
2Loose's Avatar
Am runnin' hard on other projects, but put the pipes on "as-is" and like it, am thinking WD40 frequently and keep 'em clean !!
Whadda ya think??
Willy
More HERE
Old 11-17-2016, 12:51 PM   #273
2Loose
2Loose's Avatar
Went ahead and used the VHT flat black I had on the shelf, got 'em done for now...
I even followed the recommended "baking" in my wife's oven:
250 deg half hour
cool
400 deg half hour
cool
600 deg half hour
cool
Did it while my wife was off playing bridge,
and with the windows wide open and the fan on....
(I love living dangerously....)
Willy
Old 11-17-2016, 03:27 PM   #274
2Loose
2Loose's Avatar
The wife came home....
"What'd you do...."
"Burned a toasted cheese sandwich...."
"Man, that's the weirdest toasted cheese sandwich I ever smelled...."
Back to the bike....
Hung 'em on the bike, will run 'em that way for awhile...
Still need to clean up and touch up the welds for the muffler hangers....
link to more pix
Old 11-17-2016, 09:59 PM   #275
JAWS
JAWS's Avatar
She would beat you if she knew....
ROLLING DEATH
Old 11-18-2016, 03:07 PM   #276
Lester
Lester's Avatar
Willy,
I've enjoyed this thread a lot page by page and I've picked up a few tricks I may implement to my own Pan as well. I hate coming across sounding like an ungrateful bastard by saying this: I think the pipes need more attention and rerouting. Its not that they are so bad its just that the build is coming out so good. The pipes are OK now but need to be SEXY on that bike for sure, less straight and more curves.
My hat is in my hands and head bowed.
Lester
'62 DuoGlide Mine for 23yrs
'62 Triumph T-Bird in boxes
'63 BSA Lightning Café Racer
'75 BMW R90 stock
'83 BMW R100 commuter
'70s Jawa speedway DT500
'80 couple og Jap bikes too
Old 11-19-2016, 01:00 PM   #277
2Loose
2Loose's Avatar
The pipes are going to get changed, and fairly soon, but that's an easy change to do later on.
I'm working in a friend's shop 15 minutes away from home, and I've been there too long, I need to get this done and out of his shop. So the pipes went on as is. Can't find the original '62 Linkert and intake for this bike, also have a '60 pan project stashed away, and had to go swipe that Linkert and intake, it needs a rebuild so just ordered the rebuild kit to redo it. Also ordered new original style steel chrome oil lines, and need to hook up my "new" front disk brake system, and wire it. And I need to get that done SOON !!
Home responsibilities keep slowing me down though, like a big family gathering for Thanksgiving that I am involved in, keeping me away from the shop more than I wanted....
Oh well...
Willy
Old 11-19-2016, 11:48 PM   #278
JAWS
JAWS's Avatar
It was on the shelf. I knowit was and we moved it to the racks next to the Olds.
ROLLING DEATH
Old 11-20-2016, 11:20 AM   #279
2Loose
2Loose's Avatar
Originally Posted by JAWS View Post
It was on the shelf.......
That's what I thought, but I've looked thoroughly and can't find it...
The carb for the '60 needed a rebuild anyway. so will do that and if I find the '62 carb later it can go on the '60.
Old 11-20-2016, 12:37 PM   #280
richbob
richbob's Avatar
1) priority 1 motorcycle
2) riding the fucker or fuckers
3) the rest of the other mundane shit .
