Home made workshop tools - Page 7 - The Jockey Journal Board
Old 11-09-2010, 08:03 PM   #121
76JOSH
76JOSH's Avatar
Default Re: Home made workshop tools
agreed, this thread is awesome, keep em coming.
76JOSH is offline   Reply With Quote
Old 12-19-2010, 10:55 AM   #122
knuckleworks
knuckleworks's Avatar
Bttt
Old 12-19-2010, 11:07 AM   #123
DANGER
DANGER's Avatar
30 ton press for bending bout anything!
Name:	30 ton press.jpg
http://dillonsculpture.tumblr.com/
Instagram - DillonSculpture
DANGER is offline   Reply With Quote
Old 12-19-2010, 01:17 PM   #124
cornfed
I made this welding cart from scraps laying around the garage & also my old homemade bike table (with a dumpster scored tire clamp & a flush mounted jack for easy rear tire removal.
cornfed is offline   Reply With Quote
Old 01-28-2011, 04:13 AM   #125
knuckleworks
Originally Posted by knuckleworks View Post
this 4 have the later adjuster in the how to
any one capable of helping me do a cnc cutting file to make new lower dies for these babies?? i can make a rough drawing in paint with radius and dimensions
//janne
uıɐƃɐ ʎɐqǝ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq ɹǝʌǝu ןן,ı
Lex Talionis
R I P Tippo 110426 my best friend for 13 years,you're missed
Old 01-28-2011, 08:22 AM   #126
DarkGoat
you guys should check out Lindsey publications. They have a lot of books on how to build it...very cool stuff.
DarkGoat is offline   Reply With Quote
Old 01-28-2011, 12:11 PM   #127
knuckleworks
the english wheels you mean?? thoose i have built
but need a more radius lower die to choose from
Lex Talionis
Old 02-02-2011, 07:18 PM   #128
Blacksmith54
Blacksmith54's Avatar
For an English wheels I have made I found that the self aligning bearing are aways perfect and from a surplus store most of the time cheap receiver hitch tubing works more than good enough to use for the moving parts as long as everything lines up under tension they work perfect and very predictable.
Name:	English Wheel finished no paint feom the back.jpg
ID:	59165   Click image for larger version
Name:	English Wheel finished painted red - Copy.jpg
Blacksmith54 is offline   Reply With Quote
Old 02-02-2011, 11:03 PM   #129
BCOWANWHEELS
Heres my bike stand i just finished tonight for my pan-chop makeover I can work down low anymore without it really hurting . all 3"x 1/4" angle and 1/8" thick tray. super strong
Name:	PANHEAD CHOP FEB 2,2011 003.jpg
ID:	59172   Click image for larger version
Name:	PANHEAD CHOP FEB 2,2011 002.jpg
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
Old 02-02-2011, 11:26 PM   #130
MarkWinch
MarkWinch's Avatar
Originally Posted by flattracklarry View Post
Sorry man, but ^that^ thing looks like a quick trip to the ER.
HAHAHA I love this thing! ER or not! Anything to save a buck!
MarkWinch is offline   Reply With Quote
Old 02-03-2011, 12:46 AM   #131
thecarfarmer
thecarfarmer's Avatar
Originally Posted by chopaweeza View Post
It works very well and will replicate bends easily. I use a high tech method to replicate bends. I mark the hub with a piece of chalk and then bend the next piece to were the chalk mark is. I used a Holden Barina hub which is common as muck here , Blackjack used a Ford Fiesta and I've heard some guys in the USA use Rabbit or Jack Rabbit(memories not so good) hub as well. It's a very flexible design that has at least 12 variants that I know of . It's Low Tech but it works. Here's where to find it.
http://www.thefont.pwp.blueyonder.co...ube_bender.htm
Barina, AKA: the mighty Geo Metro. Look out for the one in Seattle with grafitti on the back hatch that says "Yeah, I'm driving a Metro... what are you compensating for?"
BTW, if a guy has a 30 ton press, what the hell will he need fat chicks for?
Also, I bought a real cheap dolly, swapped out the pneumatic tires for solid, welded on a chain to retain bottles, a hook for goggles, and added a tube to hold welding rod... DIY welding cart. Sorry, no pics; it's in storage twenty miles away.
-Bill
thecarfarmer is offline   Reply With Quote
Old 02-03-2011, 01:39 PM   #132
knuckleworks
can you take a real close up on your lower bearing?? mine has standard items as well but i would love to have a more radius to swap between
cheers
/7janne
Lex Talionis
Old 02-03-2011, 07:23 PM   #133
Blacksmith54
The diameter of a self aligning ball bearing is the same as if it was sphere so if the diameter is three inches the radius is 1.5 along the axis so if you want a larger radius get a bigger bearing.
Name:	English Wheel finished painted red detail.jpg
Old 02-03-2011, 08:46 PM   #134
pitbovver
Home Made Lift Table (kinda)
The Thread
http://www.jockeyjournal.com/forum/s...ad.php?t=79716
pitbovver is offline   Reply With Quote
Old 02-04-2011, 11:02 AM   #135
knuckleworks
sorry i explained like an arse , i meant a smaller tighter radius but the gearings get really small and useless in my opinion then
//janne
Lex Talionis
Old 02-04-2011, 07:57 PM   #136
texas rattler
texas rattler's Avatar
great stuff! the best tool i ever made was a bike bench/table out of wood from an old easyriders article 60.00 versus 600.00 for a lift table, ive used my table for 20 yrs. best thing ever! 24" tall x 8' long x 36" wide and a 2x12 for a ramp.
texas rattler is offline   Reply With Quote
Old 02-04-2011, 09:17 PM   #137
Blacksmith54
I got stuck doing some wood work today and needed a way to remove some wood fast so I made a slick out of a piece of an old file a piece of bar stock and a chunk of twisted bar stock and apiece of pipe. spent about ten minutes making this
ID:	59309   Click image for larger version
Old 03-02-2011, 08:12 AM   #138
bdavanza
bdavanza's Avatar
Default Triumph Exhaust spigot tool:
Excuse the ugly welds, I had only a stick welder and old rods at the time. This is based on a harley type footpeg mount, gets those spigots in and out without bending screwdrivers.
bdavanza is offline   Reply With Quote
Old 03-02-2011, 08:24 AM   #139
Ed
TI_Tuesday
Ed's Avatar
ghetto fork tube holder that works great
5
6
Ed is offline   Reply With Quote
Old 03-02-2011, 08:30 AM   #140
bdavanza
bdavanza's Avatar
Default Chain Tool
I made this chain tool from needle nose vice grips. I heated and bent the tips, then ground them down. This tool lets you hold a chain under tension which makes sizing a chain and masterlink installation/removal much easier.
