Home made workshop tools - Page 15 - The Jockey Journal Board
Old 02-13-2014, 07:06 AM   #281
Richard D
Richard D's Avatar
Send a message via Yahoo to Richard D
Default Re: Home made workshop tools
Originally Posted by old.wrench View Post
Could you give some dimensions? I can't really tell how it works.
I have always liked the '36 Ford spare tire ring as a fender trick, so I got a Packard tire ring, which is nice because it has a piece of stainless trim around it. It has the right width for my tire, but it's too big in diameter. Your tool will reduce the diameter, without making it wider, am I correct?
Richard D is offline   Reply With Quote
Old 02-14-2014, 09:39 PM   #282
old.wrench
old.wrench's Avatar
Richard D.
When using the "fender tweeker" tool (or two 2 X 4's used as levers) to tighten a fender radius, you're always going to gain some on the fender width. When using 2 x 4's, I've always ended up spreading the fender quite a bit because you end up pushing right near the fender's edge. With the "tweeker" you can apply the force closer to the fender's center or crown because you can trap the fender in place, so it can't move away from you when you apply the outward pressure.
The fender in the picture is stamped "Made in England" and it started out 31-1/2" from tip to tip and 6" wide. After working it in the "tweeker" a bit, it now measures 29" from tip to tip and 6-1/4" wide. Just right for the Pan project I've been working on .
Not sure which dimensions you'd like, but here are a few of them -
The two long arms are about 4 foot long (long enough to give some serious leverage). The bottom arm is stationary, and the top arm pivots. The pivot point on the top arm is 6" measured from the end. The pivot is a 1/2" bolt and it's adjustable for height with 3 holes drilled at 3", 4", and 5" to the centers, measured up from the bottom of the lower leg. The hardwood "shoes" that contact the fender are 3" long x 1-1/2" x 1-1/2" (approx.) and contoured to match the fender profile. The shoes bear on the pivot arms and are backed up with an angle iron clips that in turn are bolted to the arms. That L-shaped bracket that traps the fender in place and keeps the fender from pushing away or up also can be adjusted by sliding it and locking it down with a bolt. I'm pretty sure I've managed to make this thing sound a lot more complicated than it is . It's simple to build out of scrap and odds and ends, and it's real easy to use. It'll work on fenders from 4-1/2" to 8" wide.
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 02-14-2014, 10:17 PM   #283
foureasy
foureasy's Avatar
Concrete guy, awesome idea and if you have the clamps, its so easy. I really need to go through this whole thread.
foureasy is offline   Reply With Quote
Old 03-06-2014, 11:57 AM   #284
Lester
Lester's Avatar
Here is a Home brew lathe tool that I had forgotten until the other day when I needed it again. Not in daily use but a good additon. This is a ball turning tool and it pretty easy to make. The frame is of Aluminium and I am turing Stainless 316 with out problems
Also note the brass handel on the tool.
Lester
'62 DuoGlide Mine for 23yrs
'62 Triumph T-Bird in boxes
'63 BSA Lightning Café Racer
'75 BMW R90 stock
'83 BMW R100 commuter
'70s Jawa speedway DT500
'80 couple og Jap bikes too
Old 03-06-2014, 04:59 PM   #285
Stinky Pete
Stinky Pete's Avatar
Lester - that is a cool trick!
Geo - same goes for you! Can I come over to your house and shrink my smooth wassel fender?
Railing against the darkness.
Old 03-06-2014, 05:11 PM   #286
old.wrench
old.wrench's Avatar
Stinky Pete,
For sure, shoot me a p.m. and we'll get together on it.
Geo.
Old 03-11-2014, 02:30 PM   #287
knuckleworks
knuckleworks's Avatar
i have a small benchgrinder and only use it for small bits and shapening drillbits,it's modified to accept 5" flapdics on one side and has the fine stone for DB on the other,but i wanted it to be able to rotate and still stay in place on the lift table,well i found a new turn plate for fat tv's and bolted them togheter and to the table,an ecenterlock keeps it from swiveling in use
uıɐƃɐ ʎɐqǝ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq ɹǝʌǝu ןן,ı
Lex Talionis
R I P Tippo 110426 my best friend for 13 years,you're missed
Old 03-11-2014, 03:18 PM   #288
JAWS
JAWS's Avatar
That's the cat's pajamas....
ROLLING DEATH
Old 06-07-2014, 12:57 PM   #289
Rob Axel
Rob Axel's Avatar
not a "big" tool but.... I had to make a gasket for the kicker cover. Had no punch for the holes, did the next best thing. Took a pneumatic tool adapter and a carbide tip and sharpened the inside of the inlet and punched clean holes...
"...your not wrong,....your just an asshole"- The Dude
Old 06-07-2014, 02:11 PM   #290
old.wrench
old.wrench's Avatar
There you go ^^^^!
That's a good tip Rob.
You can make just about any size of gasket or leather punch you could ever want by sharpening either the outside or inside edge any tube or piece of pipe. Yours looks like its made from an air line fitting.
Geo.
Old 06-08-2014, 07:16 AM   #291
mblab
Spent rifle casings work well for hole punches.
Mike
mblab is offline   Reply With Quote
Old 06-08-2014, 07:20 AM   #292
magnum45pete
magnum45pete's Avatar
Mike
''Spent'' is the word here!!!....make sure the Primer is popped ! hahahahaha
Old 06-08-2014, 12:52 PM   #293
Sturdly
Sturdly's Avatar
Springer spring compressor. About $3 worth of 5/16 allthread, nuts, washers and pipe hanger strap. Doubled up the strap cause this new Chinese or Indian stuff is not much thicker than tinfoil. Pretty exciting listening to it creak and groan but it held even when tightening my forks with both upper and lower internal springs.
Sturdly is offline   Reply With Quote
Old 06-08-2014, 05:50 PM   #294
joe49
Ya, but with a live primer, you won't have to get the little plug out of the case.
Old 06-08-2014, 09:49 PM   #295
JAWS
JAWS's Avatar
Great idea!
ROLLING DEATH
Old 06-08-2014, 09:58 PM   #296
govmule84
Wannabe Hipster
Mike
Maybe a bit OT, but spent casings have some other values, too... modern-day Keihin carburetors do not have flathead idle mix screws - they are 'D' shaped. You can buy that expensive ass tool, or flatten one side of a .223 case and use it. I don't have a pic of mine, but one lives in the tool pouch of one of my bikes.
Old 06-10-2014, 10:13 AM   #297
ELpolacko
ELpolacko's Avatar
I suppose I can qualify my tools as "Home Made" but probably stretching that line a bit.
My sheet metal tools:
My shrinker-stretcher stands, down to two of these right now.
My big fab table
Follow me: Website Facebook Instagram Photobucket
ELpolacko is offline   Reply With Quote
Old 06-10-2014, 10:24 AM   #298
ELpolacko
ELpolacko's Avatar
Adjustable engine stand I did for a Triumph Trident engine.
Helve Hammer:
Stamping dies to emboss sheet metal:
Collet wrench for my Pullmax:
Hard Tail Fixture:
Jug fixture to do cut new intake ports in VL jugs:
Old 06-10-2014, 11:05 AM   #299
Drake9
My big fab table
That table is awesome. What is the spacing on the holes and are they threaded? How thick is the table top?
Current Ride
81 Sportster Project
My Blog
http://bublitzbikes.blogspot.com/
Drake9 is offline   Reply With Quote
Old 06-10-2014, 11:09 AM   #300
ELpolacko
ELpolacko's Avatar
Table top is 5'X12' 1/2" thick and the holes are 1/2-13 threaded on 6" centers.
Eventually I want to replace the top with 3/4 or 1" plate with more holes. But this works very well for now.
