Home made workshop tools - Page 13 - The Jockey Journal Board
Old 12-02-2013, 04:41 PM   #241
Customize IT
Default Re: Home made workshop tools
You guys are making me jeolous with these grinder stands and grinders!!
Customize IT is offline   Reply With Quote
Old 12-02-2013, 05:05 PM   #242
Mr Bill
Mr Bill's Avatar
Well, seeing as how you brought it up...
No matter how low you sink there's still a right and a wrong, and you always end up choosing.
You go one way so you can try to live with yourself.
You can go the other and still be walking around, but you're dead and you don't know it.
Mr Bill is offline   Reply With Quote
Old 12-02-2013, 05:37 PM   #243
Customize IT
That is fabrication porn!!!
Old 12-03-2013, 12:47 AM   #244
Dan Boy
Dan Boy's Avatar
I can see why you call yourself "Grinder Bill"!
Blown Triple Build
When I was a boy, I thought about being a biker. Now I'm a biker, I think about being a boy.
Old 12-03-2013, 07:25 AM   #245
Ducbsa
Makes me think of the scene in Fastest Indian where Burt trims his toenails with a grinder.
Old 12-03-2013, 07:46 AM   #246
Mr Bill
Mr Bill's Avatar
I didn't choose the name. I did, however, earn it.
Old 12-07-2013, 05:18 PM   #247
Gobi
Gobi's Avatar
Verry inspiring! I love to see your idears!
Here are a some from my workshop:
Gobi is offline   Reply With Quote
Old 12-07-2013, 05:56 PM   #248
old.wrench
old.wrench's Avatar
Nice spoke wrench Gobi!
Geo.
"it ain't rocket surgery"
"hony swacky mally asbestos"
Old 12-08-2013, 06:01 AM   #249
Gobi
Gobi's Avatar
Thanks, i did the wrench in a black smith course i took a few years ago, its forged with hardened steel.
The sliding capilers of this kind you may know, i#m measuring /marking everything with them.
The threader is extreme, its a M50x2, I need it for repair of cylinderheads, there is no space for a normal holder, even not for the normal threader. So I had to grind it down and build the holder from inside
I didn't use the idicators in the first picture anymore, it was a nice idear, but they are to "nervous"
Old 12-22-2013, 05:39 PM   #250
old.wrench
old.wrench's Avatar
I recall that a while back we were talking about using small hand-held type grinders in conjunction with a lathe as sort of a poor-mans tool post grinder. I had a small laminate trimming router that I adapted for that purpose which eventually smoked itself. I needed another one to do some O.D. grinding on a star hub inner sleeve so I scrounged around in the shelves and found a old Roto-Zip which looked like it would do the trick. Took the original handle off of it and bolted a piece of flat bar in it's place so I could clamp it in the tool holder. It will never take the place of a real tool post grinder (like a Dumore), but it works pretty good. The on-off switch is in a handy position too. Don't forget to wear your googles .
Geo.
Old 12-23-2013, 03:07 AM   #251
knuckleworks
knuckleworks's Avatar
Geo.
I'll steal that idea
uıɐƃɐ ʎɐqǝ ɟɟo pɹɐoqʎǝʞ ɐ ʎnq ɹǝʌǝu ןן,ı
Lex Talionis
R I P Tippo 110426 my best friend for 13 years,you're missed
Old 12-23-2013, 09:12 AM   #252
little d
little d's Avatar
Geo,
Dad did that on a wood lathe once, never thought about it on a metal lathe, Damn good idea!
Old 12-23-2013, 12:38 PM   #253
Dan Boy
Dan Boy's Avatar
I'm curious, why would you need a little grinder on a lathe. What you you do with it that you couldn't do with a lathe tool. Just curious!
Cheers Dan.
Blown Triple Build
Old 12-23-2013, 12:42 PM   #254
knuckleworks
easy way of getting a grove or a flatside dead straight on a bit of round bar or something for thoose of us not having a mill
Lex Talionis
Old 12-23-2013, 01:28 PM   #255
M.O.Ther
M.O.Ther's Avatar
Cheers Dan.
In addition to what knuckleworks said, you can work on material that's too hard to cut. You could surface a brake rotor that would be likely to chatter with a cutting tool. With a fine enough grit of grinding stone, you could get a finish not possible with cutting tools and accurate to a size not possible with polishing. Once you figure out how to hold it, and with a coolant flow, you could grind the edge/radius of a glass lens to make it fit a smaller light housing. I'm sure there's more.
Old 12-23-2013, 01:36 PM   #256
Dan Boy
Dan Boy's Avatar
^thanks guys, that's really interesting.
D.
Blown Triple Build
Old 12-23-2013, 02:05 PM   #257
old.wrench
old.wrench's Avatar
Cheers Dan.
Dan,
The application I usually use it for is if I need to make a real light cut and I need a fine finish, for example, on stuff like bearing surfaces. It also works on materials that are a real bitch to cut with traditional lathe tools (as MOther mentioned), such as hardened bearing races The last project I used it on was a star hub inner sleeve bearing surface. The surface was a little galled, and I needed to take off about .0015. (Maybe I should have taken a pic, but the hub is already rebuilt and assembled.) I could have done it with a traditional lathe tool and then polished it, but the poor-man's tool post grinder did it faster and better, and I believe more accurately .
Geo.
Old 12-23-2013, 07:44 PM   #258
Tim The Grim
Tim The Grim's Avatar
You can also use a tool post grinder or old.wrench's Roto-Zip setup in a lathe to grind some material from the base circle of of an XL cam. You have to very carefully rotate the chuck by hand through the limited arc required and sequentially feed the carriage between strokes but it does the job. I saw this done back in the early '70s when guys were trying to "Hot Rod" their Sportsters on a budget.
Of course it provides extra lift and duration but not a scientifically designed cam profile.
My lathes is always wrapped in plastic bags when I use a grinder on it to keep abrasive off the ways.
'54 KHK, '76 XLCH, '96 Valkyrie
Tim The Grim is offline   Reply With Quote
Old 12-24-2013, 06:08 AM   #259
Ducbsa
Very is the key word there!
Old 12-24-2013, 10:18 AM   #260
chassy55
I use mine to reface valves. Gotta be an accurate setup, though. I use a collet and get good results.
chassy55 is offline   Reply With Quote
