Jetting a L Series Carb for EL Panhead - The Jockey Journal Board
Old 05-15-2017, 02:08 PM   #1
CastIronDuke
Default Jetting a L Series Carb for EL Panhead
Hi gents, I have a late L Carb and want to jet it correctly for a 1000 cc EL Panhead, anyone got a starting point for me?
Thanks H
CastIronDuke is offline   Reply With Quote
Old 05-15-2017, 02:26 PM   #2
FredoTwoWheels
FredoTwoWheels's Avatar
Default Re: Jetting a L Series Carb for EL Panhead
You cant find jets for them anymore really. The main jet is the same used on the E carbs, so you can replace that, but the other two you will have to drill out. Get a set of the little drill bits and read up on how to tune a carb, then increase he hole sizes and try to find a nice setting that runs for you. If i is too rich you will need to solder them closed and redrill. I have original L manuals if you need them, DM me your email.
Name:	Screen Shot 2017-05-15 at 12.29.05 PM.jpg
VL SPRINGER FRONT LEGS WANTED
IG: PineboxRecording
