Decel wobble around 50MPH - Page 2 - The Jockey Journal Board
Old 05-12-2017, 08:09 PM   #21
76shuvlinoff
Default Re: Decel wobble around 50MPH
decel wobble in my 76 swingarm just needed snugging the neck a touch. Forget the book, do it till its too tight then back off a frog hair.
Swingarm bearings need to be right too but obviously that's not the OP's issue.
76shuvlinoff is offline   Reply With Quote
Old 05-12-2017, 10:33 PM   #22
Motocrash
Motocrash's Avatar
Hey Rhys. You say the rear was recently worked? Could it be your rear wheel isn't 100% in line with the chassis? Or maybe the axle bearings a bit loose? A lot of "front end" problems can be attributed minor ass-end wonkiness.
Is it bar shake, or more of a weave? A weave would have me taking a long hard look at the rear end.
My Build: Bottom Feeder
Motocrash is offline   Reply With Quote
Old 05-13-2017, 03:57 AM   #23
rhysmort
rhysmort's Avatar
Hey dude!
no it's tamping it's a wobble, a weave I had which was my rear wheel, and then I had it redone by a guy who does race bikes. I've put more air in my front wheel and it's lessened it. I think the bearings may need a little more snug or it could be as mentioned the neck. But I don't think so.. so many variables!!
Old 05-13-2017, 08:21 AM   #24
joe49
This is from early '70s. Pressures may be better using FX numbers as it has a smaller front tire and lower pressure than running a 16" tire
Old 05-13-2017, 10:54 AM   #25
Ratso
Ratso's Avatar
Twenty-six looks a lot more like it to me. And that's with old-fashioned tires (which, rhys, I assume you're running) that have real stout sidewalls. Modern-ish tires would want more like 32, 35psi.
Old 05-13-2017, 11:07 AM   #26
rhysmort
rhysmort's Avatar
Thanks both.
Yeah Rats, running a cross ply firestone 5.5", so maybe I need a little more in the rear as well! I have 30 in the front also (speedmaster)!
Old 05-13-2017, 11:22 AM   #27
JAWS
JAWS's Avatar
Small easy bites first.
Air pressure.
Wheel bearings are trickey. Ball bearings run in grooves that MUST stay aligned perfectly. The inner spacer is there to keep things happpy when snugged down. They dont need reefed on as there is no preload like a tapered bearing. There cant be any play either. If you can feel side to side play they need replaced.
Neck bearings need the correct "fall away". Factory I think is 3-4* from center in either direction. Done with the bike level and off the ground. If the neck is raked or deraked, then it to feel. There should be no play up and down or side to side at all.
ROLLING DEATH
Old 05-13-2017, 12:12 PM   #28
richbob
richbob's Avatar
It's not a sports bike .
Balance your front wheel
Then play with the rest.
(Maybe something you have to live with I presume your not stock?)
Old 05-14-2017, 06:32 AM   #29
Thunderbird
/\/\ what Richbob says, balance, check neck tweaked down and not slack then consider heavier springs in springer, narrow bars / rabbit ears are going to accentuate any wobble then if you can't 'ride around it' fit a steering damper; that could be a first on a chop.
Old 05-14-2017, 06:58 AM   #30
rhysmort
rhysmort's Avatar
It's minute anyway man, I had 16 PSI in my rear cross ply tyre, I'll bet that's helped a lot of it too. Neck bearings are all good.
It's small amount anyway just gets on your nerves!!
Old 05-14-2017, 11:18 AM   #31
JAWS
JAWS's Avatar
I thought you already balanced both wheels?
ROLLING DEATH
Old 05-14-2017, 11:23 AM   #32
rhysmort
rhysmort's Avatar
Front wheel hasn't been done Brandt.
Rear was rebuilt by yours truly and then gone through by a local guy who's done 1000's
As mentioned previously I had 17 PSI it turned out in the rear. For Cross ply tyres you need to run a minimum of 25 due to the design of the tyre. I haven't gone out today as I've been tidying bits up and also waiting for new main shaft seals for my tranny.
Should be fine. The wobble was less with more air in the front tyre, I also have narrow bars which are welded to my top clamp so I guess it'll never be "perfect" but If I can get it as smooth as possible as we all know, springers leave a lot to be desired in most cases anyway!
Old 05-14-2017, 03:35 PM   #33
JAWS
JAWS's Avatar
Mine dont wobble or hop.
Balance that wheel.
ROLLING DEATH
Old 05-14-2017, 04:17 PM   #34
rhysmort
rhysmort's Avatar
Balance that wheel.
Stopping my tranny greasing my whole frame is the priority! it's next on the list!
Old 05-16-2017, 06:11 AM   #35
Motocrash
Motocrash's Avatar
Get that shit fixed bruddah!
Old 05-16-2017, 07:49 AM   #36
[JP]
[JP]'s Avatar
I dont have the front or rear wheel balanced.. been riding like that for 5 years.
I just live with it really, adds to the excitement ahahhaa. wonder if I should get it done.
what weights should be used? the ones clamped on the spokes?
Instagram - JPINTHEUK
My 76 Shovelhead build - http://www.jockeyjournal.com/forum/s...d.php?t=100698
My 68 Genny Shovel - http://www.jockeyjournal.com/forum/s...d.php?t=128618
Old 05-16-2017, 09:34 AM   #37
joe49
FYI the way out of a wobble is to accelerate. This is counter intuitive your instinct is to slow. That results in fork collapsing down lowering rake and shorting trail, when you need the opposite, and when you accelerate the bike wants to stand up and go straight. Best to do it immediately, before you get to tank slapping.
Old 05-16-2017, 09:40 AM   #38
joe49
Spoke weights look the cleanest. Stick on's can be more accurate. But as you can attest if not to far out you will have no trouble, other than uneven tread wear.
Old 05-16-2017, 10:43 AM   #39
rhysmort
rhysmort's Avatar
Yeah.. Mines minute but I guess with a suicide shift should get it perfect!
Old 05-16-2017, 11:28 AM   #40
magnum45pete
magnum45pete's Avatar
POINT....No such thing as Suicide SHIFT !!!.... suicide Clutch yes, & Jockey shift....
In reality unless you have a shaft drive you don't need to balance the rear wheel as the chain is only ever on part of the sprocket.
thus your rear wheel is always out of balance,...
but fronts should be balanced and correct tyre pressures used,
check them weekly,
it takes seconds and saves lives and makes riding more pleasurable, better & easier steering with less Vibrations to give ya White knuckle.....
& ya Tyres will last longer.....
also, remember a cross-ply on the rear & radial on the front is Illegal in England, if plod stops ya its 6 points + a fine........
