1940 SS Knucklehead: People's Champ 5 Build" - Page 8 - The Jockey Journal Board
Old 01-10-2017, 04:44 AM   #141
[JP]
[JP]'s Avatar
Default Re: 1940 SS Knucklehead: People's Champ 5 Build"
Awesome stuff dude as I said to you before.
I dont get tired of looking back and forwards through this whole thread and/or your IG.
Instagram - JPINTHEUK
My 76 Shovelhead build - http://www.jockeyjournal.com/forum/s...d.php?t=100698
My 68 Genny Shovel - http://www.jockeyjournal.com/forum/s...d.php?t=128618
Old 01-10-2017, 07:33 AM   #142
newman
Thanks everybody. It is flattering as hell. I don't think I deserve accolades of this magnitude, but it sure makes me smile and pushes me on.
Last night I spent all night bending up sissy bar parts. I made another one of my wood dies (in 8" CLR) so I had some nice sweeping bends. My original plan was to use 3/4 tube (instead of the "standard" 5/8 rod) to match the tubing on the girder. Well I bent up all the pieces and then took a step back. Too big. Definitely too big. I was thinking it would look beefy, but it just looked dumb, so I am going to remake it in 5/8. It is about 3 feet tall (from the axle plate).
More later. Since the next one will be rod, I will probably just use the standard "bending board" vs the bender.
newman is offline   Reply With Quote
Old 01-10-2017, 10:45 AM   #143
ericthebeard
ericthebeard's Avatar
Interesting concept, would be fun to see it still (though I believe you that it would look bulky). Makes me think of the Ewe Ehinger BF8 knucklehead, with the 1.75" exhaust routed as a "sissy bar"
IG @eric.the.beard
Old 01-20-2017, 10:18 AM   #144
newman
I wrote this up for a DIY forum, so it may seem very simplified, but I just copied and pasted. Deal w/ ittttttttt….
When people hear "Bird Deflector", they probably think it's some sort of windshield or fairing for a motorcycle, colloquially however, a bird deflector is a carburetor inlet cover designed to keep giant things (birds) out of your engine. I run one on my 59 Panhead that looks like this. That little finned johnson between the "pans". There are a zillion of these on the market today, but I wanted something that was just a hair bigger than the small one I have on the pan. (about 10% bigger). There is no air cleaner used, so you suck in all the dirt and dust, but you keep out the pant legs and birds.
Started out with a hunk of 1/2" thick 316SS and a pattern I drew in cad. I punched 3 reference marks.
Then used a compass to make the shape. I decided at the last minute to not round the end of the teardrop.
Cut it out (slowly) on the vertical bandsaw. When cutting SS this thick I run the saw blade at about 90 surface feet per minute. That's essentially the velocity of the tooth.
Then sanded to final shape with a very coarse grit (24) vertical belt sander.
Then I carefully started sanding the edges, taking care to make sure the sanding was symmetrical and consistent.
A little deeper. Trying to make a ridge build up at the point of part. This took extra attention. For this part of the sanding I am using an angle grinder with a 24 grit wheel.
More sanding. Try to use as many reference areas as possible. When doing this i was conscious of both the edge "thickness" remaining, as well as ensuring that new the teardrop of the top plane was evenly offset from the outside edge.
Up until now, all of the sanding has been on the same plane. Usually when rounding parts, I'll try to make one major cut on a plane that's tangent to where I need to remove the most material (though this is a big estimate).
Here's an example: For rounding a 90 degree corner by eye, I will take a big cut at 45 degrees
Then two more smaller cuts on the new edges I create
This method works best when you can scribe a circle on the edge needing to be cut, but by eye it's good too.
Using this method gets you a pretty nice shape, even when just doing it by eye. I know this sort of seems obvious, but for a long time when I would try to round corners I would stick the part up against the belt and start rocking it back and forth and my corners always looked a little wonky. Secret message: Helicopter Dick. Doing it this way really makes a difference. The bird deflector was a little different. My first cut was probably around 30 degrees off horizontal, but changed a bit as I got toward the rear.
A little more sanding on a new plane.
Then I started using a dynafile, which is the best tool on the planet for metal fabrication, as far as I am concerned. You can see it in the background here. They are not cheap (about 500 bucks) but it is amazing. There are tons of belts available, but I use 60/120/240/400 and blue scotch brite the most. However, I think this pic was shot after using a 36 grit belt. Note that the electric version of this tool is FAR inferior to its pneumatic counterpart. It just cant spin fast enough to be effective in my opinion.
I use model: 14000
But it's also important to have contact arm: 11234 which allows you to smooth parts better.
More dynafile work. 120 grit.
Then I used a scotchbrite blue belt on the dynafile to blend the major sanding marks and see how my shaping was.
Looks pretty good.
Old 01-20-2017, 10:18 AM   #145
newman
Making sure the raised ridge was centered and straight was critical.
It needed a little "flair" so I put it in the bridgeport (non-CNC) mill and cut some little steps in it. I roughed them in with a 3/4 roughing endmill at about 200 RPM (this pic) then radiused them with a 3/8 ball nose endmill.
Ok, I know a few steps got skipped here, but all I did was smooth out my cuts from the endmill with a blue dynafile belt, then used a pedestal buffer...
Like this. It's important to make sure you are running the correct SFM for your buffing wheel, (I run mine about 5000). To calculate SFM take your buffer's output speed and multiply it by your buffing wheel diameter and then by PI/12. In this case 1800 X 12 X 3.14/12 = 5652. I just bought some larger wheels to really get the SFM up there, so I'm excited to try those.
First you use a sisal wheel with black rouge (this will remove the dynafile scotchbrite scratches if you're dilligent and use a lot of rouge).
Then I do final polish with a spiral sewn wheel and green rouge. You can go one step further and use an open buff, but I find it doesn't do all that much on my stainless stuff, which is usually pretty curvy. I think for largely flat things you'd see it more.
Shiny.
Hope you enjoyed the trip! One thing to note is that every bird deflector I have ever seen mounts with bolts through the front, but I'm trying to avoid that and am devising a way to mount it with no visible bolts. It will be mounted with the point facing the rear of the motorcycle.
Old 01-20-2017, 10:24 AM   #146
AlexHershey
Wow. Beautiful looking piece. I dig the little steps.
Sent from my iPhone using Tapatalk
AlexHershey is offline   Reply With Quote
Old 01-20-2017, 11:20 AM   #147
rhysmort
rhysmort's Avatar
love that deflector man!
Not a huge fan of them, like my link too much to cover it, but that's a lovely piece of work.
Old 01-23-2017, 02:58 PM   #148
newman
Updates.
So I needed to make a sissy bar. Here's some of the process.
Make a drawing and tape it to some metal:
Punch important holes:
Drill some of the important holes.
Use some marking dye and a scribe for the other ones:
Take some randome shit metal:
And make a bending spool. This will keep your sissy from smooshing around the tight top bend. Note, this was made on a manual lathe by making stepped cuts then sanding:
Weld that shit to your sissy jig:
Make a bending die for the center. Step one, make a pattern and trace it onto a board. Then clamp it to a second board and drill a bunch of holes. This can be easily done on a drill press:
Bolt two boards together:
Sand bolted boards smooth:
If you are using 1/2, 3/4, 1 or 1.5 tube/rod, you can skip this step, but I had to regrind a router bit from R3/8:
To R5/16:
Use a router to take a 1/4 round out of half of your die:
Then bolt it back together:
Bolt your die to your sissy fixture and start bending. The top bend went great. The die shown in this picture didn't work out:
But this new one did:
Not shown are two more dies I made for the bottom. But it bent up pretty good. The top is super tight and nearly perfect. Not smooshed flat at all.
The top is actually a little long, about 1/4", but that doesn't matter:
Next I scabbed together some scrap to bend the top at the same time. This worked well.
Old 01-23-2017, 02:58 PM   #149
newman
Unfortunately no pics before polishing, but here's a video from after polish:
https://www.instagram.com/p/BPY1sVTF...en-by=ctnewman
Next I made some sissy bar mounting brackets for the axle plates. Started with 1/2" 316 plate:
Cut a little Z into it, that I would never be able to bend:
Made a socket on the lathe and welded it on:
Then polished them up. L&R:
Then a bunch of stuff happened and I bolted a spare transmission and my engine cases with a flywheel and pinion shaft to the bike and test fit a chain/belt... more on the primary belt in a few days.... I have some issues...
Love this view. I have been sweating whether or not it will look too "gimmicky" with the external drive but in my opinion it doesn't. Much respect to the work that CWZON did on his turbo knucklehead, but I didn't want to have the bike look this "wacky".
I think I have successfully avoided wacky, and in my opinion just made it unusual. What're you guys thinking to that point?
Old 01-23-2017, 04:04 PM   #150
ericthebeard
I think its a great balance... and balanced is a very good aestetic ideal IMHO.
So much so that I think many people, especially the uninitiated, will not really "See" it so much as notice the overall effect it has on the bike's stance and feel. Perfect.
IG @eric.the.beard
Old 01-23-2017, 05:42 PM   #151
govmule84
Wannabe Hipster
I hated the idea of sprocky and rotor on the outside when I first saw this comin' together, but I like it in practice much better than in theory.
My taste really sucks. I need to have things jammed down my throat. What's the plan for a fender?
Old 01-23-2017, 09:04 PM   #152
Ratso
Ratso's Avatar
Did Helicopter Dick help you with this build in some way?
Old 01-24-2017, 02:27 AM   #153
Deucefanny
Deucefanny's Avatar
Cool as fuck dude!
The JJ, it's like having a thousand Dads!
Deucefanny is offline   Reply With Quote
Old 01-24-2017, 03:01 AM   #154
richbob
richbob's Avatar
Looks Good.
but maybe a little dangerous for your Pillion passenger (chain guard?)
Old 01-24-2017, 07:13 AM   #155
image1's Avatar
looks great! ...but i still can't get with the handlebars, something just doesn't work there (imo)
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 01-24-2017, 07:37 AM   #156
newman
At this point they're just a placeholder. Having something there is better than nothing. The top part of the bars will be probably one of the last things.
meatspin.com
Don't click that.
I was a little nervous about it, but I was committed right out the gate so I had to stick with it. I am happy I did, because otherwise I think it would just be more of the same. I like having some engineering involved in the build.
For the fender, I have a twinrib unit from easyriders japan. I don't see them very often. I really wanted to make my own tins for this build, but I think that's going to have to wait for another bike. I won't be modifying this much, but I will be probably do a lot of work to whatever tank shell I start with.
In fact, here is a picture of the fender I took last night after making the seatstay brace/fender mount/oil tank mount. I really need to repolish the seatstay tubes, I really scratched them to hell sitting on the frame and making chopper sounds. Anyway, this part you will never see, but I'll know it's there. I also wanted to try turning something and bending it. I like trying new things. I really wish I had sone something more uniquie for the rear trans crossover.
In case you are wondering how that was made on all manual equipment:
Old 01-24-2017, 07:39 AM   #157
Just Passin' Thru...
Beautiful work newnam! ....ill go back to lurking here.
Old 01-24-2017, 07:56 AM   #158
newman
Originally Posted by Just Passin' Thru... View Post
newnam
I laughed out loud at this typo. I need more sleep.
Old 01-24-2017, 09:02 AM   #159
doh! made me chuckle too... I need more coffee.
Old 01-24-2017, 10:32 AM   #160
Rigidspeedtwin
Rigidspeedtwin's Avatar
Looks great. The frame lines are very good and the bars front and back work well with the frame. I might maybe just lay the sissy bar back a touch more to line up better with the fork, but that depends if the angle works for the seat or not. I really like the outside drive. Can't wait to see what the pipes might look like... This bike is a work of art.
Rigidspeedtwin is offline   Reply With Quote
