1940 SS Knucklehead: People's Champ 5 Build" - Page 15 - The Jockey Journal Board
Old 05-11-2017, 08:28 PM   #281
reverb
Default Re: 1940 SS Knucklehead: People's Champ 5 Build"
...hello; with this humble lathe that a buddy has, the pieces finish with some marks so I needed to start polishing like sanding (with a coarse grit)
May I ask with what grit do you start to polish these pieces; specially the ones like this mount that have welds?
Thanks
Old 05-12-2017, 08:37 AM   #282
newman
I generally use 120 grit then go straight to a blue belt with lots of pressure. consumes a lot more media but is the least amount of time.
newman is offline   Reply With Quote
Old 05-18-2017, 01:40 AM   #283
Lester
Lester's Avatar
Originally Posted by VonWegener View Post
As usual a fascinating post. Your desire for uniqueness and then the execution of your ideas is beyond anything I have ever seen.
DITTO VW!
I look forward to this thread being updated up at the same time I know its one step closer to being completed and make me uneasy, just don't want it to stop is all.
Lester
'62 DuoGlide Mine for 23yrs
'62 Triumph T-Bird in boxes
'63 BSA Lightning Café Racer
'75 BMW R90 stock
'83 BMW R100 commuter
'70s Jawa speedway DT500
'80 couple og Jap bikes too
Old 05-25-2017, 01:55 PM   #284
newman
Been doing a bad job of keeping the forum updated. Pretty current on Instagram though.
Made this trans plate from 316. Since I was making it to fit the trans case I had, I was able to maintain on;y .002 clearance fit on the alignment tabs on the bottom of the transmission so the belt adjustment stays super square.
Next I worked on some clutch linkage. All these parts are stainless and handmade, with the exception of the cone cable clamp nut. All parts have bronze bushings at pivot points. Cable rides around a pulley to actuate clutch throwout fork.
HERES A VIDEO THAT IS PROBABLY CLEARER: https://www.instagram.com/p/BUIrD-TFTqT
Old 05-25-2017, 01:56 PM   #285
newman
Then I pressure tested my frame since it’s also the oil lines. No leaks! Also added two ports with supermag drain plugs in it. Here’s a video describing the oil flow path: https://www.instagram.com/p/BUXdb6elmhX
I also had to make an NPT to banjo adapter so I started with an off the shelf fitting:
And made it nicer:
Old 05-25-2017, 01:56 PM   #286
newman
Next I made a kicker pedal shaft. I made it so that it folds in real far allowing me to get my foot on the pegs:
Then I made the actual pedal out of sheet metal.
Old 05-25-2017, 04:08 PM   #287
Mick93
Mick93's Avatar
great work man, I cant imagine how much time you have invested in this bike.
Allergic to Stock
pushing the limits since 67
Mick93 is offline   Reply With Quote
Old 05-25-2017, 04:27 PM   #288
FredoTwoWheels
FredoTwoWheels's Avatar
Dude, I hope you sell this thing for $150,000. I would say this is the most work I have personally ever seen put into a bike. You may as well build a motor from scratch at this point.
VL SPRINGER FRONT LEGS WANTED
IG: PineboxRecording
Old 05-25-2017, 06:00 PM   #289
JAWS
JAWS's Avatar
Newman!!!
ROLLING DEATH
Old 05-25-2017, 07:53 PM   #290
tomsoftail
tomsoftail's Avatar
The art Deco vibe this thing has is an architectural flair too. I don't have the words to say it. Nice job, Newman!
Old 05-25-2017, 08:18 PM   #291
Stormin
I joined JJ at the time to witness this awesome build. The vision, dedication and patience are off the charts, and you are doing a superb job in keeping this thread updated. Very enjoyable watching. Thank you!
