1940 SS Knucklehead: People's Champ 5 Build" - Page 14 - The Jockey Journal Board
Old 05-08-2017, 10:41 AM   #261
newman
Default Re: 1940 SS Knucklehead: People's Champ 5 Build"
Then it was time to make some brake linkage. All I used to make this was an angle grinder, a drill press and a bandsaw.
Then I made some more pieces… here’s a bit more detail, should be pretty self explanatory.
newman is offline   Reply With Quote
Old 05-08-2017, 10:41 AM   #262
newman
Then welded those parts on a part I made on the lathe, blended the welds and polished them:
I wanted some unique clevises, so I had to make those as well. Here’s how I did that. Turn OD
Use grooving tool to profile
Sand smooth
4 pieces done
Then put in the mill in the rotary table and slot and drill.
Old 05-08-2017, 10:41 AM   #263
newman
The last step I didn’t take photos for, but I put the part back into the lathe and profiled the rest of it with the groover and sander. And this is how the parts looked when done and “installed”
Then I had to make mounts for the master cylinder and the pivot linkage. I did the math to have the end result of the braking force be equal to that of my sportster, which is comfortable to me,
based on leverage ratios, master size, caliper pot size, etc. Fab tip: it’s often helpful to fab small brackets and things while they are still attached to the stock which is helpful for clamping, drilling, sanding polishing, etc. Also, protip 2: don’t smash your thumb while changing brakepads on your car.
Here’s a video of the actuation of the master:
https://www.instagram.com/p/BTvYai1F...en-by=ctnewman
After that it was time to build a front portion of the front pipe. I had a midsection cast off a 3d printed wax model, bolted that to the frame, then built a pipe from 304 using vband flanges to mount
it. I had to make the flanges but used an off the shelf clamp.
Here are several shots of the exhaust.
Old 05-08-2017, 10:42 AM   #264
newman
And here’s a tool I made to make cutting tubing easier and more accurate. First, set the angle and lock it down.
Then add the hold down ring and clamp that down. The whole plate slides in the miter groove of the saw and you get perfectly radial cuts every time.
You need one for every CLR tube you have, and every diameter, but since I really only build Harley exhausts, I made 1.75 OD X 2,3,4,6 CLR. I need to make a 1.75CLR still.
Old 05-08-2017, 11:12 AM   #265
VonWegener
VonWegener's Avatar
As usual a fascinating post. Your desire for uniqueness and then the execution of your ideas is beyond anything I have ever seen.
Old 05-08-2017, 11:44 AM   #266
rhysmort
rhysmort's Avatar
As always man, it's a pleasure to see your stuff! that's seriously skinny, watch those drains when you ride may fall in the gaps!
Old 05-08-2017, 12:12 PM   #267
ericthebeard
ericthebeard's Avatar
The breakdown with what you get after each step of the process (layout, bandsaw, grind, polish) is fantastic.
And that trick of putting washers over the flat bit when shaping the arms is genius!
IG @eric.the.beard
Old 05-08-2017, 03:50 PM   #268
Ratso
Ratso's Avatar
Genius, period.
Old 05-09-2017, 02:47 AM   #269
richbob
richbob's Avatar
Beautiful.
Will the mag go in more? or thats the spot?
Old 05-09-2017, 10:28 AM   #270
ericthebeard
Originally Posted by richbob View Post
Beautiful.
I'm assuming he's going for a side-mounted mag to save shaving the regulator boss off (what is now) a very rare set of cases.
IG @eric.the.beard
Old 05-09-2017, 02:23 PM   #271
newman
This is correct. The relay boss is in good shape so I didn't want to hack it up.
Old 05-09-2017, 02:29 PM   #272
newman
Made a top motor mount. Nothing fancy here. I wasn't feeling exceptionally inspired when I was designing it.
Used 1/8 filler rod which made blending the welds a lot simpler than the welds on the foot control bracket. Also made a fixture to hold everything true because I knew I was going to be putting a lot of heat into it. It pulled a little bit, but it pulled evenly, so I will probably have to run a .030 shim behind the center bolt.
Fit well. There will not be an issue with the rocker tins interfering...
Then got it polished up. Polish only took 3 hours which isn't bad.
Old 05-09-2017, 08:19 PM   #273
Deucefanny
Deucefanny's Avatar
I think I'm gonna have to make the trip from AUS to Born Free just to see this bike. Fuck the detail and skill is awesome.
The JJ, it's like having a thousand Dads!
Deucefanny is offline   Reply With Quote
Old 05-10-2017, 09:41 PM   #274
KCgran
What kind of saw blade is that? My experience with stainless is you have to cut it with a carbide cutting wheel or tooling?
Old 05-10-2017, 09:53 PM   #275
HD48FL
Super Moderator
I can't speak for Newman, but I use Lenox Bi-metal blades for aluminum, stainless, and CRS.
Old 05-11-2017, 07:18 AM   #276
newman
I use Lenox as well. Specifically:
Lenox DIEMASTER 2 Bi-Metal Band Saw Blades 3/8 x.025 14/18V
They last a really long time.
I get them from bandsawbladesdirect.com
Old 05-11-2017, 11:18 AM   #277
rhysmort
rhysmort's Avatar
+3 probably the best blades about. They last for a literal age. Worth every penny.
Old 05-11-2017, 11:28 AM   #278
rhysmort
rhysmort's Avatar
Old 05-11-2017, 04:52 PM   #279
4444Design
4444Design's Avatar
your fabrication skills are awesome
Chrome won`t bring yer home!
4444Design is offline   Reply With Quote
Old 05-11-2017, 08:01 PM   #280
Wisco Cal
With everything else so far over the top, a "mildly" kustom motor mount won't go unappreciated. I like it.
Wisco Cal is offline   Reply With Quote
