1940 SS Knucklehead: People's Champ 5 Build" - Page 13 - The Jockey Journal Board
Old 03-30-2017, 04:34 PM   #241
Ratso
Ratso's Avatar
Default Re: 1940 SS Knucklehead: People's Champ 5 Build"
How'd you do that?
Old 03-30-2017, 05:26 PM   #242
KCgran
I'm betting the first one was done with a ball end end mill on a rotary table in a mill, or a CNC mill. I bet Newman did his by hand with his air file!
Old 03-30-2017, 10:55 PM   #243
newman
Originally Posted by Ratso View Post
How'd you do that?
Haha, nailed it, although the dynafile did factor strongly into the final shaping!
newman is offline   Reply With Quote
Old 03-30-2017, 11:58 PM   #244
Ratso
Ratso's Avatar
The second one, though. Is that hand work?
Old 03-31-2017, 07:53 AM   #245
newman
File and lathe!
Old 03-31-2017, 05:54 PM   #246
Ratso
Ratso's Avatar
Thankew.
Old 04-03-2017, 11:10 AM   #247
newman
Made a shift knob from a marble and some 12GA 316.
Better view here:
https://www.instagram.com/p/BSU70KQl...en-by=ctnewman
Also made these vband exhaust spigots. I'm hoping I can weld or braze them onto the head, but I need to do some more research about that.
Old 04-03-2017, 10:54 PM   #248
knuck39
beautifull work Newman....you are a true craftsman...
knuck39 is offline   Reply With Quote
Old 04-07-2017, 06:12 PM   #249
skinny
skinny's Avatar
great job with that black & white "shooter".
keep it coming brother!
skinny
"Late night, freeway flyin' always makes me sing...yeah, it always makes me sing"... Tom Waits
skinny is offline   Reply With Quote
Old 04-14-2017, 08:52 AM   #250
newman
Scrambling trying to get the engine together and working on 3 things at once. Seat at at upholsterer, tins are at painters. Focusing on trying to get the engine built so that I can get the exhaust and foot controls built.
Here are some things that happened in the past week:
Made some special stud covers to close off the holes in the CE reg I modded.
Started working on some floorboard pedal thingers:
Always a shame grinding off (semi) pretty welds
I got this cast exhaust piece that I designed. It goes underneath the trans and will have vbands on both ends.
I welded my vband flanges that I made a few posts back to the head. Super high stress job. Took about 7 hours. Preheat, weld 3/8", back in the oven, repeat, then slow cool down cycle. Welds looked good and no cracks. Then I powdercoated them wrinkle black which may not be everyone's thing, but I like it. Valve guides and rocker shafts are one-off... I have a plan coming together there. Rocker shafts are out getting carburized now.
Last night I bead blasted and prepped the case for glyptal. Me and my buddy Dave at BA enterprises put new Jim's main races in the case and honed them. Cover bearings reamed, lots of threads fixed, etc. Hoping to put the bottom end together this weekend. I think I have all the parts.
Old 04-14-2017, 09:30 AM   #251
hd74
hd74's Avatar
First I want that shifter knob, but you continue to impress...
My Chopped Pan http://www.jockeyjournal.com/forum/s...d.php?t=131586
hd74 is offline   Reply With Quote
Old 04-14-2017, 09:35 AM   #252
rhysmort
rhysmort's Avatar
I personally love wrinkle black, my horseshoe is done in it, looks so good finished.
Flanges may be a god send, the old style ones are such a pain in the ass, my back pipe will literally not stay tight!
Lovely welding too man!
Old 04-14-2017, 01:29 PM   #253
ericthebeard
ericthebeard's Avatar
Why is that little section on the left case near the breather channel masked off from the glyptal?
Thanks for continuing to post up progress!
IG @eric.the.beard
Old 04-14-2017, 01:51 PM   #254
newman
It's the scraper plate. Old timer who is helping me with my motor says it needs to be masked off, so i masked it off. He explained why but I was doing it at like 2 am and can't recall.
Old 04-14-2017, 02:49 PM   #255
KCgran
I thought it would look great on your bike as soon as I saw it!
Old 04-28-2017, 09:56 AM   #256
newman
Been working hard.
Got everything from the cylinders down together permanently. Motor is rebuilt from the flywheels up. Doing all the motor work at BA Enterprises in Lockport NY. He's very knowledgeable. Waiting on valves before I can do final top end assembly.
Here's how it sits now.
But Dave was going out of town for Oley for the week so I brought the motor back home to start on exhaust and foot controls.
Fits in the frame well. Had some concern about the vband clamp clearance but I think I am golden.
I'm running an MM74E and if you have ever used one you know there is a little round spacer that goes under the mag bolting flange. It's purpose is to be able to drop the body to install the mag head. Well that idea is great but the spacer leaves a lot to be desired. I replaced it with this:
Next, I committed chopper blasphemy and machined some adapters to reduce my top end oil feed ports from 1/2-20 to M10x1.25. I did this because there are a lot of awesome banjo bolts available in that size, and I don't have time to be making bolts right now. Time is running out.
Last night I finished up my footpeg/floorboard/pedal things. You may remember these from a few posts back:
Hope to get them mounted and have some functioning linkage in the next week or so, then on to the exhaust.
Old 04-28-2017, 11:36 AM   #257
ericthebeard
On the floorboards... trying to reverse engineer them between the "in progress" shots and the finished product.
Are the wavy fins in the final product inserted from the bottom of the slots shown before? Are they welded from the bottom with a slip fit so there's no gap or fillet to smooth or polish on top?
So rad BTW. I love mini-floorboards.
Are they going to be high-mounted? I imagine that with the whole skinny theme putting them at least on top of the primary (rather than beside) would follow logically...
IG @eric.the.beard
Old 04-28-2017, 01:57 PM   #258
newman
They are inserted from the top. There are small tabs that poke slightly through the bottom which I welded after polishing and installing.
My plan is high mids. I have to figure that out exactl placement still.
Old 04-28-2017, 05:49 PM   #259
thomassuman@mac.com
thomassuman@mac.com's Avatar
you'll sell a lot of those floorboards at a buck apiece
very nice work
thomas
thomassuman@mac.com is offline   Reply With Quote
Old 05-08-2017, 10:40 AM   #260
newman
Ok, got some work done the past couple days.
First things first I had to mount the footpegs, so I started by cutting out some 316 on the saw, then smoothing it and bending it up.
Then I welded on some gussets:
Then did a test fit. Seems to be going well so far…
Then I polished them up. This video shows what they looked like after polish. https://www.instagram.com/p/BTh-Uhjl...en-by=ctnewman
After that, I mounted the floorboards on.
It’s shocking how skinny it is!
