Slabside Shovelhead - Page 7 - The Jockey Journal Board
Old 05-08-2017, 01:41 PM   #121
VonWegener
VonWegener's Avatar
Default Re: Slabside Shovelhead
The mag sits nice in there. Dressing the fins really makes the difference.
Old 05-09-2017, 01:20 PM   #122
vinlesposito
vinlesposito's Avatar
A little more progress last night. Mounted the mikuni VM38 carb and put this silly NOS cable wrap on the throttle cable
72 Triumph TR6R
61 Triumph Bonneville
69 Shovelhead/53 Wishbone
Old 05-10-2017, 01:22 AM   #123
JAWS
JAWS's Avatar
Thats pretty.
ROLLING DEATH
Old 05-11-2017, 05:09 PM   #124
4444Design
4444Design's Avatar
I remember those "cable covers" had them on my bike back then also ...
doesn`t look that shabby anyway
Chrome won`t bring yer home!
4444Design is offline   Reply With Quote
Old 05-25-2017, 09:23 PM   #125
vinlesposito
Well, after months and months of messing around with this bike I gave a shot at tying to start her up. I had great hot spark from the Morris mag, sounds like I had good compression and fuel was getting to the Mikuni, but no luck. I think I need to give the carb a little tuning with the air mixture screw, but not even a little sputter was disheartening �� If anyone has any experience tuning a Mikuni on a shovelhead, any tips would be appreciated.
72 Triumph TR6R
Old Yesterday, 06:37 AM   #126
geezer
geezer's Avatar
Jetting? And are you sure on the timing? Plugs wet?
Old Yesterday, 07:32 AM   #127
vinlesposito
For sure on the timing, I followed the step by step instructions from Morris
72 Triumph TR6R
Old Yesterday, 07:47 PM   #128
750Devo
750Devo's Avatar
How do you know you are getting good spark when the plugs are in the bike and fighting the compression?
Kicking a mag fired bike requires a very fast kick. Speed is everything. I learned this by putting an inline tester between the spark plug and spark plug wire. Lights up when plug actually sparks. Kicked bike in the dark to see what it took to get good spark in real life conditions
The testers are pretty cheap and is a quick and easy way to determine if your problem is carb or ignition. If it is a mag issue there are a few tricks I can tell you to make things easier. If its the mikuni I know nothing.
I dig stoopid knuckleheads, and pissing into the wind
IG @devonnalder
750Devo is offline   Reply With Quote
Old Today, 05:48 AM   #129
vinlesposito
Inline tester is a good call Devo, never thought of that. I checked spark by pulling one plug at a time, grounding it against the case and giving the bike a good kick. Each plug had a nice blue spark, but like you said that could be different when in the cylinder fighting compression
72 Triumph TR6R
Old Today, 09:13 AM   #130
joe49
Plug gaps at .025-.028 ?
Old Today, 12:35 PM   #131
750Devo
750Devo's Avatar
According to Morris plug gap for magneto should be 0.020-0.025. Smaller the gap the easier it is to kick over. I run mine at 0.018, but mine is running 11 to 1 compression ratio.
IG @devonnalder
Old Today, 01:05 PM   #132
joe49
oops memory isn't what it used to be. Hunt say's .018-.025 and solid core wires and no resistor plugs.
Old Today, 04:09 PM   #133
750Devo
750Devo's Avatar
I had to look those numbers up myself... to many things to remember obout these bikes for any one person to remember haha
IG @devonnalder
Old Today, 04:45 PM   #134
vinlesposito
Haha so true! Thanks guys, I'll scope the plug gap. I got my wired direct from Morris when I picked up the mag, using their suggested Champion plugs as well
72 Triumph TR6R
