Slabside Shovelhead - Page 6 - The Jockey Journal Board
Old 04-19-2017, 06:21 PM   #101
vinlesposito
vinlesposito's Avatar
Default Re: Slabside Shovelhead
Does anyone have a simple wiring diagram for running with a mangeto and no battery? Seems like I just need one wire from the generator to capacitor to the ignition switch, and a few more for headlight/tail light an brake switch.
72 Triumph TR6R
61 Triumph Bonneville
69 Shovelhead/53 Wishbone
Old 04-19-2017, 07:59 PM   #102
shovithead
shovithead's Avatar
Correct, and why a key switch? Just a toggle will do, and it is next to useless, since you will have no battery.
See Rhysmorton, he runs the same setup. He is currently adding a rear tail light and brake light on his. But, yes, genny to cap, then wire what you need. I am sure he will chime in, when he sees this. Not that he can add anything. But, he can tell you his experience.
72 Chevy C30 truck
73 Custom Shovel
72 XLH
70 XLH
69 XLH
68 XLCH *project*
66 FLH *Daily Rider*
66 Shovel/Pan/Pan
65 XLCH *project*
60 XLCH Doc Dytch*project*
51 FL *project*
42 UL*project*
Non Dated, S&S Panhead with 65 swingarm *project*
Old 04-19-2017, 11:14 PM   #103
JasonMcElroy
JasonMcElroy's Avatar
Just pretend the battery in the diagram is a capacitor. They are the same really, batteries just hold a charge a bit longer.
Also erase the ignition coil and point (in brown) coming off the IGN position. You don't want to send voltage to your magneto.
Old 04-20-2017, 07:15 AM   #104
vinlesposito
Awesome, thanks Jason
72 Triumph TR6R
Old 04-20-2017, 05:01 PM   #105
rhysmort
rhysmort's Avatar
I've literally got a single wire through my whole bike for back and front light. If you can crack it, will work like a dream!
Old 04-21-2017, 03:19 AM   #106
richbob
richbob's Avatar
Old 04-21-2017, 11:26 AM   #107
rhysmort
rhysmort's Avatar
Originally Posted by richbob View Post
I have half the wires that does! depends how basic you want it! Cycle elec capacitor, one wire from there to headlight to rear light that's it!
Old 04-21-2017, 02:12 PM   #108
richbob
richbob's Avatar
Brake light is handy
Maybe no traffic up your country
Old 04-21-2017, 02:13 PM   #109
image1's Avatar
you also have a generator, that diagram is for alternator bikes.
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 04-21-2017, 04:52 PM   #110
rhysmort
rhysmort's Avatar
Same wire sir.
Old 04-21-2017, 04:52 PM   #111
rhysmort
rhysmort's Avatar
Yeah, just stating it's doable!
Old 05-07-2017, 12:05 PM   #112
vinlesposito
Picked up this guy a few days ago, pretty psyched on it. Morris Mag 74E. Went to install yesterday and was having trouble getting the hex alignment correct. Instructions say to set it to the points "just about to open" and inspect if the mag studs align with a flat or a point. I was able to figure that out but had to take the base out a few times, shift the driver and install again to try to get it right. After about 6 attempts I called it quits, need to give it another crack again today.
72 Triumph TR6R
Old 05-07-2017, 12:16 PM   #113
ericthebeard
ericthebeard's Avatar
Have you watched this?
It was really useful for me to have a complete visual walkthrough.
IG @eric.the.beard
Old 05-07-2017, 12:34 PM   #114
vinlesposito
I literally just watched! Thanks Eric. Im basically going through those steps again. Whats happening is I'm installing with the points opening so it doesn't matter if i turns the mag, the contact is still broken. I stepped away for the night, gonna jump on it with a clear head
72 Triumph TR6R
Old 05-07-2017, 01:31 PM   #115
magnum45pete
magnum45pete's Avatar
remove the drive from the motor and turn the shaft a tooth & re=fit until it lines up,... real simple,...... the drive gear has (if I remember right) 10 gear flutes, and the drive hex has 6 faces so a finer movement can be achieved using a combination of the two.
Old 05-08-2017, 05:45 AM   #116
vinlesposito
And shesis. Basically did what Magnum45Pete said above. Took a few tries and a little trimming of some cyclinger find but she's in and timed. For anyone looking into a Morris, these guys were a joy to deal with and I 100% suggest picking up the timing tool.
72 Triumph TR6R
Old 05-08-2017, 08:41 AM   #117
magnum45pete
Glad you got it done & that I was able to help,
Dave at Morris Magneto's is a great fella and very helpful,...I used to live in the next town over (Bernardsville) and often used to go to his workshop to check out some real nice bikes he was working on,... always had time for a Coffee & a chat...
Old 05-08-2017, 08:48 AM   #118
bbqbiker
bbqbiker's Avatar
Looking good! Never ran a mag and watching carefully......bike is coming along nicely...
1952 FL
1969 FLH Bobber
1998 FLHP 124" hiway destroyer
bbqbiker is offline   Reply With Quote
Old 05-08-2017, 12:15 PM   #119
ericthebeard
Looking at the last pic... looks like you're missing the lil spacer between the case and the mag base. I'm pretty sure that's necessary to get it timed right (and maybe was causing the extra problems?).
IG @eric.the.beard
Old 05-08-2017, 12:52 PM   #120
vinlesposito
It's in there, just hard to see because the metals all look the same.
72 Triumph TR6R
