Slabside Shovelhead - Page 2 - The Jockey Journal Board
Old 10-19-2015, 01:49 PM   #21
govmule84
Wannabe Hipster
Default Re: Slabside Shovelhead
I think the J is a fine cam for a Shovel. Very stock-like reliability. Nothing but an improvement, if you ask me.
Old 10-20-2015, 06:57 PM   #22
vinlesposito
vinlesposito's Avatar
Little filler:
Front end is on its way, and should be around in the next few days. Unfortunately I have to go back to work for two weeks (engineer on a tugboat in New York harbor), so I won't be able to get to it until I'm back.
I did pick up a new, peanut style, tank from Factory Metal Works. Overall it looks great, but the front mounting tab is a little crooked. I'll take it on the boat with me, modify that and hit it with a little primer. Not totally sure on mounting options. I don't want to drill through the top tube for the rear tab, for the front tab it would be pretty tough with all that bondo underneath the paint. Luckily I have two weeks to think about it!
72 Triumph TR6R
61 Triumph Bonneville
69 Shovelhead/53 Wishbone
Old 10-23-2015, 10:20 PM   #23
vinlesposito
Can anyone running a 1.5" BDL belt drive give a little feedback?
72 Triumph TR6R
Old 10-24-2015, 02:17 AM   #24
JAWS
JAWS's Avatar
I run mostly a similar setup. Not particular to brands and like the stockish clutch. What is it you need feed back for?
ROLLING DEATH
Old 10-24-2015, 06:58 AM   #25
vinlesposito
Just curious how power transfer is compared to a chain driven primary, how durable compared to chain. Are you running it open or closed?
My train of thought at the moment is to run an open belt drive, and fab up a backing plate to keep the motor and trans aligned
72 Triumph TR6R
Old 10-24-2015, 11:55 AM   #26
Jesse_in_NY
Jesse_in_NY's Avatar
I've not ran a chain primary in years. The 1.5 has held up with all the abuse I threw at it, idler length and the shorter ones designed not to have an idler.
“Be not like those whose hearts are filled with the fear of death, so that when their time comes they weep and pray for a little more time.” Shawnee Chief Tecumseh
Jesse_in_NY is offline   Reply With Quote
Old 10-24-2015, 10:03 PM   #27
JAWS
JAWS's Avatar
Never had issue except one bike. That bike should have had a plate between the trans and motor. The five finger stock style (stock is three so this was slightly better) clutch couldn't handle the motor. Trans would sometimes come out of alignment and the clutch would slip.... The belt never gave issue or came off and got the power to the clutch fine.
Also, I rode it like an idiot.....
All of mine are open, none have had mid plates....... Not saying thats the right way to do it. Only the one was nasty enough to need it in my opinion.
ROLLING DEATH
Old 10-30-2015, 12:46 AM   #28
jake.
jake.'s Avatar
Man, this looks great already! If my red frame was like that it would have stayed!
jake. is offline   Reply With Quote
Old 11-06-2015, 09:05 AM   #29
vinlesposito
Ran out of gloves, and greasy hands don't pair well with cameras, so minimal photos from the shop last night. But front end is on and rear wheel is mocked. Need a tire for the front wheel, but once that's on I'll have a better idea on roughly final stance. May end up getting 2 over tubes but won't be totally sure until the tire comes in. For now it sits like this
72 Triumph TR6R
Old 11-06-2015, 12:57 PM   #30
VonWegener
VonWegener's Avatar
I like what I'm seeing.
Old 11-06-2015, 03:48 PM   #31
KCgran
Me too
Old 11-06-2015, 03:54 PM   #32
govmule84
Wannabe Hipster
Looks good.
I also like 1.5" belt drives. I have one on each of my Shovels, one an 8mm and one an 11mm. The 11mm has blown up once when I was riding like an asshole, but it's also one of those tensioned ones, so I think it sees some heat. I also need my primary on there for the starter and the mid, so that probably also holds in heat.
I also ran a 2" on an Evo I had, that held up beautifully too. I like belts.
I don't have any type of plates tying my motors or trannies together... they don't ever seem to move.
Old 11-06-2015, 05:04 PM   #33
Jesse_in_NY
That really does look good man. I like that it'll be lifted a bit in the front
Old 11-10-2015, 07:46 AM   #34
vinlesposito
Thanks guys!
I have a feeling it will definitely have a little lift in the front, and I think thats definitely the aesthetic I'm shooting for which will draw more attention to the awesome lines of these frames.
After installing the narrow glide front end I noticed the steering stops on the lower tree do their job correctly, but will definitely chip/ding the bondo on the neck of frame. Seems simple enough to just get some round rubber stock or tubing and slip it over the stops.
I'm in the process of moving everything from my current shop to a larger (and more importantly, HEATED) garage around the corner from my apt. Once I'm all settled in I'll pull the motor, finish assembly and start really moving forward with this build.
72 Triumph TR6R
Old 11-10-2015, 10:56 AM   #35
JAWS
JAWS's Avatar
On mine, I drilled and tapped for some 8-32 polished stainless button heads for the fork stops to contact.
ROLLING DEATH
Old 11-10-2015, 11:47 AM   #36
Jesse_in_NY
Done this before and it works great for keeping the paint from getting beat. Take your time drilling/tapping and you'll be happy with the result.
Old 11-10-2015, 04:09 PM   #37
jake.
jake.'s Avatar
Are you going to run that rear fender? Or swap out to something a little skinnier?
Old 11-11-2015, 12:54 AM   #38
vinlesposito
Definitely going skinnier, probably a ribbed Wassail style painted fender. Going with a taller sissy bar too
72 Triumph TR6R
Old 11-12-2015, 06:03 PM   #39
Jay Tyrrell
Very cool build! Will be following for sure!
Jay
Jay Tyrrell is offline   Reply With Quote
Old 11-12-2015, 09:32 PM   #40
mandrew
mandrew's Avatar
Thumbs up Re: Slabside Shovelhead
killer bike. I really dig that old chopper frame and old paint.
mandrew is offline   Reply With Quote
