Blown 45 build - Page 2 - The Jockey Journal Board
Old 11-18-2012, 10:30 AM   #21
Elffors
Elffors's Avatar
Default Re: Swedish 45 build
So i finally got around to work on this again.
The snout is done, and shortened 40mm (1.57 inches)
Next thing is to get sprockets, bearings and seal for the drive and machine a new shaft for the shortened snout.
Old 12-17-2012, 01:37 PM   #22
Elffors
Elffors's Avatar
This is a slow moving build..
Anyway, at last i got something done. I made an new shaft fore the snout fitted bearings and seals, and found out to my suprise that the shaft is'nt straight by 0.02-0.03mm and the darn thing is turning backwards..
With a little tinkering the internals could be turned upside down som now it turns the right way again!
Here's an mock up picture
I think this is gonna be great!
Old 12-17-2012, 03:20 PM   #23
servi53
servi53's Avatar
help us old guys see with some bigger pics, I still want to see where this is going, what I can see is looking good
servi53 is offline   Reply With Quote
Old 12-18-2012, 02:33 AM   #24
Elffors
Elffors's Avatar
Now the pic is bigger!
My bad. i'm not used to shrinking pics, this one got a little too small..
Old 12-18-2012, 05:15 PM   #25
spent
spent's Avatar
Lookin real good, man.
spent is offline   Reply With Quote
Old 01-14-2013, 02:55 PM   #26
Elffors
Elffors's Avatar
I must ask a stupid question...
Since we here in sweden have silly national sports like soccer and such and the americans have supercharging chevy smallblocks as theirs, i wonder do i go up in carburator size then i build a drawtrough set up or does the carburetor compensate for the added sucktion from the supercharger?
Thanks!
Old 01-14-2013, 03:44 PM   #27
Johansson
Johansson's Avatar
Hi Jon, nice to see a build thread here of your bike!
The megaphones will be even nastier sounding with an Eaton feeding them, I can´t wait to hear the result! Here is a clip I shot last summer by the way:
http://youtu.be/6yhsxWnCbvE
Cheers!
/Anders
Johansson is offline   Reply With Quote
Old 01-14-2013, 11:34 PM   #28
skinthead
It isn't a stupid question. Now that you have asked it, I want to know the answer too.
One would think you would have to increase the size of the carb at least a small amount to allow the compressor to do its job and not be straining to breathe.
I agree with your statement about it being stupid to run one lean too. I have watched far too many guys ruin a perfectly good engine trying to suck that last 0.5hp out of it by running it just a touch leaner, and leaner, and leaner.....till they find the lockup point....
www.crustybikes.net
skinthead is offline   Reply With Quote
Old 01-15-2013, 12:02 AM   #29
JAWS
JAWS's Avatar
Good question, but the looks of the pullies you are running close to 1:1 ratio.
Here's the deal, the blower is 45 cubic inches in displacement and is only about 65-70% efficient and that's at 4-8K rpm range.
The effective cubes is around 76".
That at 100% volumetric efficiency cause it's huffed makes a needed 111 cfm @ 5000 rpm.
Now what rpm is that 45 gonna be at most of the time? That is what you carb it to.
I suspect the carb you have now will be fine to start with if it was setup for a higher compression NA 45. Less cfm will limit max rpm, jets will determine fuel.
Best is to get it to idle and use a vacuum gauge at the carb base. Set it accordingly at that range. Move on to the next rpm range out of the idle circuit and jet it there. I would suggest an O2 sensor in the exhaust on each hole for best results. Maybe with another set of test purpose exhaust headers just to set it up, then when it's dialed in you can put the intended pipes on it.
ROLLING DEATH
Old 01-22-2013, 02:54 PM   #30
Elffors
Elffors's Avatar
Finally i got the thumb out of my arse and actually did something with this build!
I laced up my backwheel with a 15" dropcenter rim and mounted my new tire.
I know it's probebly rubbish but this is more show than go. A flathead 45 is never ever gonna go as fast as this is gonna look
Thats right. ratio is 1:1.
Having done some calculations with the corky bell supercharger book, i found out thats going to be about 0.69bar boost which would result in a 50bhp+ range.
But i've learned that expectations should be set looow, because you can't bench race the dyno. it never lies and never live up to wild expectations...
I've got myself an used SU HS4 1½" inch carburator. it's about what i think is the right size.
Old 01-22-2013, 03:20 PM   #31
JAWS
JAWS's Avatar
Hell yeah, that will work just fine. Get her to idle and then I would get a tuning set of pipes. Maybe some purpose built ugly ones with bungs for each hole so you can stick an O2 in there and really see, not guess what's happening. You only need one of those generic digital gauges and O2 kits.
50 hp is gonna make that little monster move out good. You're not gonna spin it high enough to make enough boost to hurt it......now change the ratio on the pullies and get the huffer spinning earlier....:0
ROLLING DEATH
Old 01-22-2013, 03:22 PM   #32
JAWS
JAWS's Avatar
like this..
http://www.amazon.com/dp/B009AP975A/...SIN=B009AP975A
ROLLING DEATH
Old 01-22-2013, 04:26 PM   #33
servi53
servi53's Avatar
Looks awesome with that HOOSIER on there. I'm running an SU on my servicar that was supposed to be good for a paperweight when it was given to me. Post up a video when you get it going, can't wait to see and hear it. keep up the good work. George
Old 01-23-2013, 02:42 PM   #34
Elffors
Elffors's Avatar
I've got one of those innovate lc1 things since my turbocharging days.
Have you ever held an japanese sportbike with 14PSI+ boost wide open on the public road, and trying to read those little afr gauges and trying to remember the reading at a certain rpm?
At the higher rpm you will be carrying the front wheel high, going at an ridiculus amount of speed............
I had enough of that, i leave the fine tuning to my dyno operator friend. Then i get my Afr on paper.
Rejet my Su, dynopull, rejet, dynopull, and so on. Til i get it just right.
thanks! Su's can carry a lot of attitude, with their slight angle.
Uppkaftigt is the correct swedish word..
Old 01-23-2013, 02:45 PM   #35
JAWS
JAWS's Avatar
Nope, can't say as I've ever ridden a boosted sportbike at wide open........My balls aren't that big
ROLLING DEATH
Old 01-23-2013, 03:15 PM   #36
Elffors
Elffors's Avatar
I see that those words came out wrong.
It wasn't bragging, it was me as a youngster doing stupid things with little respect for my own life.
Now i'm too old for that shit.
Old 01-23-2013, 03:52 PM   #37
JAWS
JAWS's Avatar
No no, I didn't take it as that. I just know that I am dumb and my right foot is heavy....I would've tried that too when I was younger.
I can't wait to see the boosted 45"er up and running
ROLLING DEATH
Old 01-24-2013, 02:49 PM   #38
Elffors
Elffors's Avatar
Then i'm not the only impatient one.
I just got a tip on an high performance oilfeedpump. Very expensive and very needed.... bugger!
Old 01-24-2013, 03:19 PM   #39
JAWS
JAWS's Avatar
You gonna run that through a large cooler right? I would run a finned tube type, more capacity and help cool that 45 just as good measure.
ROLLING DEATH
Old 01-24-2013, 03:26 PM   #40
JAWS
JAWS's Avatar
Actually I take that tube cooler back....You are a clever guy, maybe some aluminum or copper tubing tracing the frame with some small fins....Polished or not
ROLLING DEATH
