Blown 45 build - Page 13 - The Jockey Journal Board
Old 10-30-2013, 04:45 PM   #241
JAWS
JAWS's Avatar
Default Re: Blown 45 build
I wish I had a mill and lathe at home. I am thinking of twin mags. Single drive. Independently and totally adjustable.
ROLLING DEATH
Old 11-01-2013, 01:43 AM   #242
Elffors
Elffors's Avatar
Everyone should have an mill and a lathe in his garage. i'm still short of the mill but i'm working on it.
Frenchowl gave me some prints of the internals for an distributor cap for the mag.
If i feel that i got time for that too, that would be really intresting to dig into.
Highest prio is to get this thing up and running
Old 11-01-2013, 04:20 AM   #243
little d
little d's Avatar
Elffors,
not knowing any thing about mags when I rebuilt mine, I called these guys... http://www.morrismagneto.com/ . Dave and his son answered all of my questions, even some I hadn't thought to ask, they really took the time to make sure I knew what I was doing. Ya might drop them a line about single firing your mag.
BTW, your thread is one of the first ones I opened when we got moved and set back up. Love what your doing and how your doing it...
Old 11-01-2013, 06:42 AM   #244
twinspeed
Yes, this is very interesting thread... I love these old flatheads and the idea of supercharging and tuning them.
twinspeed is offline   Reply With Quote
Old 11-01-2013, 07:17 AM   #245
Elffors
Elffors's Avatar
Thanks for the kind words!
I already have what morris has to offer in terms of single fire adapters for my mag.
I will run it and expect it work.
But..
If i can make something myself thats not an ugly electronic gizmo, but an mecanical good looking, good working solution. That would be so much more badass in my book.
Nothing is impossible, it just takes more time....
Old 11-01-2013, 10:43 AM   #246
mads4
mads4's Avatar
Yeah!! We share taste in literature!
M
mads4 is offline   Reply With Quote
Old 11-01-2013, 11:43 AM   #247
JAWS
JAWS's Avatar
M
I cant read, but share the same philosophy.
My other idea was dual point plated single distributor. Wont do reverse polarity, so there will be wasted spark. It will allow for timing of the second set of plugs. Could be modified to do single fire.
Like I said Im working on it for my cone shovel.
ROLLING DEATH
Old 11-05-2013, 02:38 PM   #248
Elffors
Elffors's Avatar
Finally something happens again.
Got the throttle arrangement working. Need an return spring of the proper strenght and some bolts of the proper prettiness, but i kinda like it.
Maybe the wiregrooves in the brasswheels needs to be cut deeper, time will tell.
(It's phonepics)
Old 11-10-2013, 03:13 PM   #249
Elffors
Elffors's Avatar
It feels like there's a light in the end of the tunnel!
Last steps of the 2do list is like ten steps long but there are only 2 major things on it. The rest goes like draw fuel lines or add oil in the charger.
Major isn't so major, it's make an contrapation to hold the magneto in kicking position. Had an idea about that but scraped it after seeing a clever device on youtube. copy paste.
The other is making the SU work without fuelpump.
i Have the SU Hs4 carb and the problem area of it i think is the floatbowl needle being so small that i cant enlarge the fuel inlet enough.
But those carbs where made in Hs6 and Hs8 seizes to, so i will order an needle from one of those carbs and make my carb work with it.
After it makes it's first supercharged noises there will be tons of little stuff to fiddle with til summer so it won't be done by far when fires for the firts time
Old 11-10-2013, 04:26 PM   #250
thefrenchowl
thefrenchowl's Avatar
Hi Elffors, My inlet needles, before on right, after on left, twice the diameter, so 4 times the surface area.
The new one was just a touch sticky so I waisted it in the middle, now perfect...
Patrick
Flat Head Forever
www.harleykrxlrtt.com
www.jonghi.org
thefrenchowl is offline   Reply With Quote
Old 11-10-2013, 05:05 PM   #251
JAWS
JAWS's Avatar
Hmmmm.
ROLLING DEATH
Old 11-11-2013, 02:39 AM   #252
Elffors
Elffors's Avatar
Patrick
Well that's intresting.
But mine's is a super light piece of hollow plastic with an steel tip. I ain't sure if the original bowl has the capacity to lift an all steel needle. but you got me thinking i new patterns.
What size and make of carb do you use?
Old 11-11-2013, 07:44 AM   #253
thefrenchowl
Hi Elffors
Mid seventies S&S MGAL, 47mm throat:
You can see the 1/2 stainless line on the left. I also added an SU float chamber, all empty to increase bowl capacity from 175cc (S&S alone) to 300cc with both. It doesn't lean out after 2 miles flat out. Haven't tried yet to run a 3rd mile on the go!!!
Patrick
Flat Head Forever
www.jonghi.org
Old 11-11-2013, 02:54 PM   #254
Elffors
Elffors's Avatar
That's alot of carb!
But you run methanol and that's like 70% more fuel(?)
does it need more air to burn all that fuel?
Hmm.. i'm thinking that i might have undersized my carb...
Today i shortened the inletpipe for some better chain clearance, draw some oil lines. And ordered an "racing" floatbowl needle
Old 11-11-2013, 03:28 PM   #255
JAWS
JAWS's Avatar
Issue is btu of alcohol to gas. Depending on application will determine, well everything about cfm, fuel volume and rate of consumption.
ROLLING DEATH
Old 11-11-2013, 04:09 PM   #256
thefrenchowl
Fuel usage is very dependant on supercharger, revs, size and ratio...
I did a lot of calcs before hand and while the engine seems happy with them, fuel consumtion is now twice what the calcs said for the amount of air the engine ingests. Real mystery to me!!!
Air to gas weight ratio is about 13 to 1. Air to methanol is supposed to be half that, 6 to 1. From my jets and consumption, it's running now more like 3 to 1...
At Bonneville, it took just over a minute from standing start to crossing the end of mile 2 at 123mph and a bit. On paper, that was 1 liter of methanol needed. I'm using about 2... And my good tuning friend Richard was thinking I was still a bit lean .
Engine at about 5000rpm, charger twice that at 10,000rpm. 500cc per charger rev, so that's 5,000 liters of air ingested per mn. Every time one inlet valve opens, a liter fills one 450cc cylinder plus 100cc combustion chamber = 550cc (CR 5.5 to 1). Don't know what the pumping losses are, hard to know, I never had the engine on a dyno. All my calcs were with 10% losses.
A supercharger certainly makes your engine drinks a whole lot more of whatever you choose to feed it!!!
Patrick
Flat Head Forever
www.jonghi.org
Old 11-11-2013, 04:45 PM   #257
JAWS
JAWS's Avatar
That is true.
From my experience, which is limited, supercharged engines exceed VE. Depending on the chargers rate of compression and size, effectively boosting displacement and compression. This is known. What Ive found is closer to 3 times the fuel consumption with alcohol. It has been similar with gas as well.
I believe its the different atmospheres created above and below the charger. I also believe the sheer velocity of the fuel mix and exhaust moving through the chambers as rpm increases, causes another atmosphere change where a vacuum occurs outside the exhaust valve and port. Similar to scavenging.
Makes me wonder about exhaust configurations.
ROLLING DEATH
Old 11-12-2013, 03:26 PM   #258
Elffors
Elffors's Avatar
My only hands on experience from blown engines is my blowthrough carb turbo set up.
In such a case like that the standard carb doesn't present an restriction cause the air forced past the venturi accelerates causing a greater pressure drop across the jet drawing more fuel through the carb.
4 38mm carbs have successfully supported 400bhp on the dyno. And jetting stays almost the same as N/A!
So before this build i read some books about this and they claimed that a similar situation should be present in an drawthrough set up.
i found it a hard to belive cause bigger engines demand bigger carbs than small engines and the carb itself have no idea what ever a big engine is asking for x cfm of air or an small engine assisted by an charger is asking for the same x amount of air?
There where an discussion about this on my swedish build thread but since drawthrough charger set ups is virtually non existent in sweden i decided to go by the books an stay with the 38mm size carb i had before
My question to frenchowl where if he had to go extra large in carb size cause of his use of methanol or did he needed that size anyway cause of the charger application?
Patrick
That is true.
Old 11-12-2013, 06:00 PM   #259
JAWS
JAWS's Avatar
I know this much all cfm seems to do is limit rpm potential on a blown engine.
Simple test I found is using a vac gauge below the carb. At WOT there should be 0 vac if cfm is adequate. If there is a reading, then there is a restriction to the pressures trying to equalize. This holds true on na setups as well.
Opposite as well. If 0 is before WOT.
Bear in mind I am not talking about fuel mixes here.
ROLLING DEATH
Old 11-12-2013, 06:41 PM   #260
thefrenchowl
Hi Elfors, Jaws...
Can't really say I designed the bike with another carb 1st.
What happened was I got that carb as a gas carb on a 74 ci 1967 CH engine... Way too big for the bike so it ended up on the shelves for a long while...
Then I acquired an XLRTT, same again, 74ci, but with huge domed Dytch pistons. Wouldn't rev past 2000rpm on gas... So decided to mod the carb to methanol, n.a.
That took about 5 years to set up, not cause I'm an idiot, just that I did not use the bike that much cause of work loads, maybe 2 or 3 times a year...
Eventually, got fed up of the methanol palava on the XLRTT, castor oil, flushing oil... Put it back to std with a 38mm race Tilly fed with regular gas.
Big carb back on the shelves until I decided to build the Bonneville bike. When I received the Ansin AMR500 supercharger, the ports did impress me, about 2" x 2" square... seemed to be asking for a big carb to hand out there...
MGAL off the shelves and on the bike...
Patrick
Flat Head Forever
www.jonghi.org
