Hey I'm wondering if anyone has had this happen, or have a solution to this problem as I am driving myself mad with frustration. Here's the skinny:
1970 triumph t100s. Oil is returning to tank from motor, slower than the feed. The bottom end fills up with oil........... Burns,leaks,blows seals. That is the issue. I have cleaned out the oil lines (all, no blockage) new oil pump. Hoses are on correct locations. Originally this bike did not have an in-line oil filter, I have installed one on it. Bypassing the filter does nothing to derail this issue. This bike does not "wet sump" either so that is not the issue.
