Zodiac: The Envy of Seattle - Page 8 - The Jockey Journal Board
Old 01-07-2017, 09:04 PM   #141
ericthebeard
ericthebeard's Avatar
Default Re: Zodiac: The Envy of Seattle
Also made another big visual step in getting it looking like an actual motorcycle: Bars, grips, and throttle!
Easy and felt good. Got a pair of 30 deg drags for cheap on OldSTF. Narrowed them and shortened them to what you see here. Still playing with the angle of them, playing between "sad dog ear" forward bars and swept back drags. But I'm really liking how they play with the tanks.
IMG_0435 by Eric Bott, on Flickr
IMG_0490 by Eric Bott, on Flickr
IMG_0484 by Eric Bott, on Flickr
IMG_0488 by Eric Bott, on Flickr
IG @eric.the.beard
Old 01-07-2017, 11:40 PM   #142
Apehanger Hank
Apehanger Hank's Avatar
Drag bars on extended split risers and fat bob tanks take me back to 1969! Good job!
Hank
Old 04-10-2017, 12:55 PM   #143
ericthebeard
So, I thought I'd batch up things in this thread and not update until I get some significant amount of work done on some component. Thus far the work on the bike has been a little bit of this and a lil bit o that, and just posting a stream of consciousness... maybe not the most fun for those watching at home.
But I got good end-2-end work done on the front wheel.
The original front (if you recall) is a 1968 Triumph TLS I scored off ebay. Well, I wanted to clean it up a bit more than it was, and the rim was all covered inside with what looks like tank sealer to stave off the rust. Well, I took the plunge and rebuilt the wheel.
This was satisfying to nip the spokes and shoot the across the shop out of the rim:
IMG_0554 by Eric Bott, on Flickr
Made sure to take good notes as to the existing crossing pattern:
IMG_0555 by Eric Bott, on Flickr
Scrap:
IMG_0556 by Eric Bott, on Flickr
And got a nice fancy Excel rim and spoke kit from Buchanan's. I *think* I could have gotten away with a harley rim that would have fit the hamburger drum, but it was good peace of mind to have Buchanans dimple and drill it right, specially considering this is my first wheel and now I'll know that I should not expect much if any resistance to the lacing.
44632B6C-ACE8-4E11-B2D8-F9436EA83025 by Eric Bott, on Flickr
And another big win, once the hub was out I was able to prime and paint it, doing a proper job:
IMG_0588 by Eric Bott, on Flickr
IMG_0590 by Eric Bott, on Flickr
And also, in for a penny... got the braking surface trued at a friends shop:
IMG_0672 by Eric Bott, on Flickr
IMG_0671 by Eric Bott, on Flickr
IG @eric.the.beard
Old 04-10-2017, 12:58 PM   #144
ericthebeard
Then got the final paint on and laced it all up... pretty
IMG_0756 by Eric Bott, on Flickr
IMG_0757 by Eric Bott, on Flickr
IMG_0760 by Eric Bott, on Flickr
She has yet to be fully trued and tensioned though...
IG @eric.the.beard
Old 04-10-2017, 01:09 PM   #145
ericthebeard
Another fun mini-project win:
Got the Bareknuckle Overbearing for my tranny. Pretty excited about it if it lives up to the hype (which thus far from other people's say so it does).
IMG_0569 by Eric Bott, on Flickr
But... its much bigger than the standard tranny nut. Didnt think about that AND I just bought a std sprocket nut tool for my bike.
2 1/4"
IMG_0571 by Eric Bott, on Flickr
So. Its custom sprocket tool making time! Here's the standard tool (left), then a cheap 2 1/4" socket with a HF impact socket stacked on it. The 2 1/4" incher is a 3/4" drive, which is a large enough hole that the main shaft slips right through it, and the HF socket is long enough to take up the extra length + converts it to 1/2" drive. It all just works with no lathe or mods necessary (beside welding)
IMG_0761 by Eric Bott, on Flickr
Prep and chamfer the surfaces:
IMG_0764 by Eric Bott, on Flickr
Then affix and weld!
IMG_0771 by Eric Bott, on Flickr
IMG_0770 by Eric Bott, on Flickr
IG @eric.the.beard
Old 04-11-2017, 09:29 AM   #146
image1's Avatar
looking good, did you figure out a brake stay yet?
August 4-7, 2016!!!!!!!!!
http://r4yl.blogspot.com/
Old 04-14-2017, 01:23 PM   #147
ericthebeard
Thanks. Ive got it spec'd out in my head, bracing a tab off of the lower disc mount and axle spacer... but really need to do things like actually get the spacers measured up and cut before anything becomes a reality.
IG @eric.the.beard
Old 04-14-2017, 10:24 PM   #148
mandrew
mandrew's Avatar
I like that handle bar and riser set up a lot! Nice choice
mandrew is offline   Reply With Quote
Old 04-22-2017, 11:26 PM   #149
ericthebeard
Thanks, me too. I'm getting far enough along in the build to start to let its style speak to me...
IG @eric.the.beard
Old 04-23-2017, 12:14 PM   #150
JAWS
JAWS's Avatar
What do you still need parts wise?
ROLLING DEATH
Old 04-23-2017, 03:01 PM   #151
ericthebeard
Fundamentally not too much as far as off the shelf parts are concerned... I need brake lines/cabes, some wiring
Most all lies in custom or fab parts, I need:
-Figure out shifting linkage (still quite unknown)
-Fab exhaust mounts, finish weld exhaust
-Fab axle spacers for the front
-Make front brake anchor
-Finish off the fender/seat cowl combo
-Make the seat and seat pan
-Finish the tanks (button up the clearance notches I made and relocate the petcock bung)
-Finish the foot controls and pegs (including the front pulley guard)
-Finish electricals (mount front and rear lights, wire it all up, install light switches)
-Dish the rear wheel
-Tension/true the front wheel, mount the tire
.... Then its time for a mechanical once-over... then learn how to ride hand-shift
So yeah. Still a project
IG @eric.the.beard
Old 04-23-2017, 07:13 PM   #152
JAWS
JAWS's Avatar
Foot clutching is easy if you position your foot so it can be in the same arc as the pedal. Think old time gas pedal in a truck or like the "moon foot" style pedals fronthe 70's. Heel needs to be at the same pivot point as the clutch pedal.
On the lee style pedal I have, I use the arm and pedal as a whole. My foot isnt on the peg trying to move the pedal nor am I lifting my leg to operate it. Im simply rolling it on by the movement of my foot only. Pivoting at my ankle.
ROLLING DEATH
Old 04-23-2017, 09:57 PM   #153
ericthebeard
Sweet, thanks for those foot clutchin' nuggets.
For now I have it set up with a rocker clutch and, mainly because of the positioning of the left-side pipes, will be attempting some sort of VL-style tank shifter setup.
IG @eric.the.beard
Old 04-23-2017, 10:29 PM   #154
JAWS
JAWS's Avatar
Remember foot clutch release isnt a race.
It wont be scond nature right off the start.
However the easier it is to manage the faster it becomes second nature.
ROLLING DEATH
Old 04-24-2017, 03:34 PM   #155
ericthebeard
Oh yeah, question on foot shifting...
Especially with the rocker clutch, do people typically disengage the clutch (With the foot) for every shift past first? Or just rev-match the gears and (gently) bang them up/down?
With my lower HP bikes (like a DRZ-400) this was always pretty easy to do and convenient , but this is my first vintage ride...
IG @eric.the.beard
Old 04-24-2017, 09:23 PM   #156
JAWS
JAWS's Avatar
I always use the clutch and I always blip the throttle with the clutch in on the down shift as I shift.
ROLLING DEATH
Old 04-25-2017, 06:59 AM   #157
WillPhelps52
I sure wish I had the tools and skills you are showing.
Great job!
WillPhelps52 is offline   Reply With Quote
Old 04-25-2017, 11:38 AM   #158
ericthebeard
A little shift linkage inspiration...
IG @eric.the.beard
