Zodiac: The Envy of Seattle - Page 7 - The Jockey Journal Board
Old 07-21-2016, 06:14 PM   #121
ericthebeard
ericthebeard's Avatar
Default Re: Zodiac: The Envy of Seattle
Right now its all slung up with the chain to the tranny in neutral, and spinning it in the air there doesn't seem to be any more than the usual resistance via bearings, chain, and mainshaft...
IG @eric.the.beard
Old 07-21-2016, 11:15 PM   #122
JAWS
JAWS's Avatar
Ok good. Glad you sorted that. Truthfully I was sure you already did. Never hurts to ask. I've left simple things before as assumption and reminded by someone later to check and then the "ah ha!" moment. Where I realize..."ah ha"...I am an idiot, again.
ROLLING DEATH
Old 07-30-2016, 11:43 AM   #123
ericthebeard
Bump? Can anyone else weigh in on the rear rim centering issue?
IG @eric.the.beard
Old 07-30-2016, 11:50 AM   #124
richbob
richbob's Avatar
You have done a top job
You know what you have to do.
Triumph workshop manual on PDF available(650 unit)
richbob is online now   Reply With Quote
Old 07-30-2016, 02:18 PM   #125
ericthebeard
Thanks!
You mean dish the rim over to center from where the hub sits now?
IG @eric.the.beard
Old 07-30-2016, 02:53 PM   #126
richbob
richbob's Avatar
yea
unless you can do something with the sprocket?
Old 09-10-2016, 02:42 PM   #127
ericthebeard
Back at it for another iteration.
First off, working on welding welding welding... got a TIG machine and am super stoked on the zen of TIG vs the manic spazziod explosion of (my shitty) MIG.
Working some stringer beads on sheet:
IMG_0092 by Eric Bott, on Flickr
And melting aluminum:
IMG_0140 by Eric Bott, on Flickr
Aluminum because a) I can (its a 200 amp AC/DC machine) and b) I have a nice Lowbrow Al fender I want to use.
I've stared at what feels like MILLIONS of pics of swinger fender setups. Many fall into one of two categories:
1) far too bulky for my tastes... Crazy Frank, Stockers, ones with lots of sidewall coverage, etc) and
2) Too lean/thin, swingarm mounted ones especially, trying to copy the look that is classic and killer on hardtails).
Finger Tight strikes a very good balance, but I also want it to be good enough for a pillion and/or luggage mount. Mr Boyle has explicitly stated his whole goal with Finger Tight is a day tripper (good for him tho, such an iconic bike).
So, my mission is make simply the best looking fender setup ever.
IG @eric.the.beard
Old 09-10-2016, 02:55 PM   #128
ericthebeard
So, on the fender topic... first I played with just the fender itself, getting the standoff just right on the tire by stacking layers of old yoga and camping pad on the tire and resting the fender on there.
Then cutting down the fender a bit more.
Then a bit more fiddling... and more snipping. Note that this is all relative to the rear tire at this point, once the bike is on the ground I can do final fitment after the suspensions settles, and I choose between the shorter 12" shocks or whatnot for the final ground clearance.
IMG_0104 by Eric Bott, on Flickr
IMG_0110 by Eric Bott, on Flickr
To my eye, the "exit angle" of the fender is critical to the final look, as well as the amount of tire covered. For a pillion I'll need at least a little bit of flat section, so the fender goes to about 12-oclock. But should not curve exactly with the tire, it got to have the right "fling" off the tire line... I'm liking where this is ending up.
Then I played with card stock to work out the perfect amount of "beef" and volume for the rear end.
IMG_0117 by Eric Bott, on Flickr
IMG_0119 by Eric Bott, on Flickr
IMG_0121 by Eric Bott, on Flickr
After some snip and chin scratching... this is gonna look dope.
IMG_0124 by Eric Bott, on Flickr
IMG_0126 by Eric Bott, on Flickr
Time to get some alloy sheet on order... and practice al TIG over and over and over before I melt my nice fender.
IG @eric.the.beard
Old 09-13-2016, 08:42 PM   #129
JAWS
JAWS's Avatar
Hmmm.
I like the whole look there Eric.
How much clearance will you get fully compressed with a rider? With the suspension sagging it looks like alot, but I have a feeling when it's on the ground it will look different.
ROLLING DEATH
Old 09-14-2016, 11:38 AM   #130
ericthebeard
At this point I am deferring those questions. I am fitting up the fender relative to the tire as it sits, and will adjust when I get the bike on the ground.
I am ignoring the relationship of the fender with the frame, basically getting it to flow with the tire lines and the "volume" of the rear end in general. Once the bike is on the ground I can then get the mounting to the frame, tire clearance, and integration with the seat pan all figured out...
One crisis at a time
IG @eric.the.beard
Old 09-14-2016, 11:49 AM   #131
ericthebeard
I started mocking up the (mostly) final run for the rear exhaust section.
I went back and forth over and over again about collecting the two into once main header (like Caleb Owens' YangYang or Oliver Jones' BF7 mega-black shovelhead) or duals like Cox's Barracuda.
Honestly, the complexity of landing the rear pipe cleanly into the front was REALLY daunting and I took multiple failures at it, so went with the dual pipe route. Both would look killer IMHO.
I had to tweak the front pipe run to clear over the rear exit, but I finally got it poking out into space below it.
IMG_0154 by Eric Bott, on Flickr
IMG_0153 by Eric Bott, on Flickr
IMG_0151 by Eric Bott, on Flickr
To aid in fishing the rear section through and out the middle of the frame, I added in a slip fit section. This also decouples the final alignment of the two pie runs and will make it MUCH easier to make them dead parallel without putting lots of torque on almost-but-not-quite perfectly aligned pipes.
Mark a line with a super advanced line-o-widget
IMG_0163 by Eric Bott, on Flickr
Cut some kerfs:
IMG_0165 by Eric Bott, on Flickr
Make fit:
IMG_0167 by Eric Bott, on Flickr
And get the exit angle perfect:
IMG_0166 by Eric Bott, on Flickr
At this point I'm going to save myself the embarrassment of showing my tack welds... I have LOTS to learn about TIG still. And will have to brush up on my burn through hole filling before this job is done...
IG @eric.the.beard
Old 09-14-2016, 11:52 AM   #132
ericthebeard
And the reveal... Pretty happy how these are shaping up.
Note: both pipes are sagging a bit and will be raised to clear the clutch release arm. In fact, I should pause the exhaust building for a bit and iterate on the drivetrain before I design myself into a corner...
And there are going to be laterally slash cut tips added to the ends too. For dramatic flair and minimization of soot on the rest of the bike...
IMG_0171 by Eric Bott, on Flickr
IMG_0170 by Eric Bott, on Flickr
IMG_0169 by Eric Bott, on Flickr
IG @eric.the.beard
Old 09-14-2016, 04:34 PM   #133
JAWS
JAWS's Avatar
I like it!
I will add this....File fit your joints for tigging and V butt them. That's what I did and I used a jig to hold the pipes together.
ROLLING DEATH
Old 09-14-2016, 05:16 PM   #134
ericthebeard
Good call on that jig.
I keep bouncing back and forth between instantly burning through and not getting a good puddle.
More practice, more practice, practicing more, and trying smaller wire (down from 1/16") should be the ticket...
IG @eric.the.beard
Old 09-14-2016, 07:03 PM   #135
JAWS
JAWS's Avatar
Yup. Adjust heat til it puddles and only puddles. Back off to keep it so. I did mine with no filler. Probably should have used it to make it real pretty.
My first weld with a tig...
ROLLING DEATH
Old 09-14-2016, 07:41 PM   #136
ericthebeard
Lookin' good there JAWS!
For now I am just postponing worrying about finish welding and getting my mockups/tacks all set while getting in bench time with the TIG on the side.
IG @eric.the.beard
Old 09-14-2016, 07:46 PM   #137
JAWS
JAWS's Avatar
It is so much fun, moving the puddle. I like to get it to strike the arc and then slowly add more juice til I can see the puddle form. Takes more gas and I'm still trying to figure out the best time to add filler. I played around with Tungsten size and filler rod size.....even use mig wire for really small stuff.
ROLLING DEATH
Old 09-14-2016, 08:16 PM   #138
ericthebeard
Thats on the menu for tonight's practice. I don't have anything under 1/16 for filler, but do have some ~0.028 mig wire. May try to double up on those too and see what I get
IG @eric.the.beard
Old 01-07-2017, 08:58 PM   #139
ericthebeard
Still at it, though slow and deliberate.
Weld, cut, grind, stare, swear...
IMG_0395 by Eric Bott, on Flickr
You'll notice I got some tanks finally... though I'd been working on narrowing up my own 5-gal splits, Cody on here had a pre made set. Good quality and for a good price. I'll still work on my in the gaps, but its good to just have a solid set to work with and move forward.
IMG_0419 by Eric Bott, on Flickr
I had to do a little relieving around the heads, should be easy to patch up and all the cuts will basically be unseen under the tank, on the inside.
IMG_0413 by Eric Bott, on Flickr
IMG_0416 by Eric Bott, on Flickr
IMG_0414 by Eric Bott, on Flickr
IG @eric.the.beard
Old 01-07-2017, 08:58 PM   #140
ericthebeard
Glory shot from the underside:
IMG_0417 by Eric Bott, on Flickr
IG @eric.the.beard
