Home made workshop tools - Page 2 - The Jockey Journal Board
Old 11-27-2007, 11:12 PM   #21
RAZ
RAZ's Avatar
F.st.m. can you give us some more detail on the phase converter?
Work out?? I don`t need to work out, I get
enough exercise just pushing my luck.
RAZ is offline   Reply With Quote
Old 11-28-2007, 09:15 AM   #22
F.St.M.
F.St.M.'s Avatar
Sure Raz,
First single phase (2 hot legs) enters the knife switch box at the bottom of the box. Leg #2 is jumped(split) to power up what will become the third leg. Time-delay fuses are installed so that the breaker doesn't trip during initial start-up.
Then the third leg power is sent down to a start capacitor. It returns up and into the momentary (light switch) switch. It then goes down and "bump starts" the idler motor which is bolted to the side of my mill.
With zero load on the idler motor, it creates a steady third leg (L3) which can now be used by the mill & lathe.
Though still a bit messy, the circuits can be identified on the wall board in this last photo. When running only one machine, the circuits (L1, L2, & l3) are very well ballanced and the "created 3rd leg" is at 92% - 96% amperage which is just about perfect. When running both(mill & lathe) machines simultaneously, amperage on L3 drops to 88% so I just plug in to the dayton run cap (blue star in photo) and this brings it back up to 95%.
Total expenses were $80 this includes the idler motor(ebay), fuses, romex, capacitors, and light switch. The knife switch came with the mill when I got it, so that was a freebie.
F.St.M. is offline   Reply With Quote
Old 11-28-2007, 10:15 AM   #23
Jeff L
Jeff L's Avatar
I converted a 9" benchtop drill press into a makeshift vertical lathe for polishing aluminum tubing.A live center on the bottom & a bow roller off a boat trailer that I cut in half & reshaped on the top.
Jeff L is offline   Reply With Quote
Old 11-28-2007, 12:34 PM   #24
scootermcrad
scootermcrad's Avatar
OH HEY!! That's a great idea!!!
Blogs are weird... here's mine!
http://scootermcrad.blogspot.com/
scootermcrad is offline   Reply With Quote
Old 11-28-2007, 09:23 PM   #25
1fastfx
1fastfx's Avatar
Originally Posted by F.St.M. View Post
Sure Raz,
I have heard of this done before but nobody explained it as well as you have.Nice job ,esp when multible applications are needed.I have printed this and put in my notes for future reference.....Thanks
1fastfx is offline   Reply With Quote
Old 11-28-2007, 10:10 PM   #26
VA Rebel
VA Rebel's Avatar
F.St.M.
I applaud your make do creativity, but your electrical installation is a disaster.
Get an enclosure for those live parts before someone gets zapped. Those lugs are an electrocution hazzard, especially with either motor under load.
VA Rebel is offline   Reply With Quote
Old 11-29-2007, 12:07 AM   #27
Pearson Customs
Here is my home made mill, back in trade school each of us made parts and then we all put them together and we each had a mill.
Chad
www.pearsoncustoms.com
Pearson Customs is offline   Reply With Quote
Old 11-29-2007, 12:31 AM   #28
kbg
wheeling machines, got plans off internet, made two one paid for
mine.
kbg is offline   Reply With Quote
Old 11-29-2007, 09:59 AM   #29
Dan
Dan's Avatar
a stand for holding stuff, the arms adjust vert. and horizontaly
neck fixture for an as yet unfinished frame jig
probably too dark to see but a combo wheel chock / tie down
over center bike lift
some mods to a HF tubing notcher
kids in shop class using a T-dolly
this table has been one of the most useful things ever, has casters and makes moving things around the shop super easy, a '26 roadster is sitting on it now and I just push it around the shop
homemade Les Paul
Dan is offline   Reply With Quote
Old 11-30-2007, 09:01 AM   #30
Dan
Dan's Avatar
The thing was actually pretty decent for a HF tool right out of the box. The only things I did were mount it to a good heavy base (I built a wood one first but the 1/4" steel plate is much better). The biggest problem I found is that the pipe clamp didnt quite line up with quill, hole would be drilled off center. All I had to do was put some shim stock between the pipe clamp (the black piece) and the frame (the gray piece) to line it up. I think the biggest secret to making it work is good hole saws.
Old 12-15-2007, 10:43 PM   #31
ca180
ca180's Avatar
Just found this online... Guy says its for forming tunnels for bike gas tanks.
ID:	23336   Click image for larger version
ca180 is offline   Reply With Quote
Old 12-15-2007, 10:53 PM   #32
caschnd1
caschnd1's Avatar
I use this tool to pressure test my intake manifold. Super easy to find even the smallest leaks.
  1. Remove the carb
  2. Bolt this onto the end of the intake using the rubber inner tube "gasket" to seal it up.
  3. Put my air compressor hose on the nipple and adjust the regulator to 10psi.
  4. Spray all around the intake o-rings with water with a little bit of dish soap.
If you have a leak, you'll get lots of bubbles. Much more reliable way to find intake leaks then spraying around the intake with WD40 or carb cleaner.
-Craig
caschnd1 is offline   Reply With Quote
Old 12-15-2007, 11:03 PM   #33
ca180
ca180's Avatar
Good Idea, I need to make one of those
Old 09-25-2008, 09:10 AM   #34
Concrete B
I've been in the mood to make some items for the garage. I'll get pics of my metal brakes, english wheel, and parts washer and post them up. In the mean time....bump.
Concrete B is offline   Reply With Quote
Old 09-26-2008, 01:10 AM   #35
JeffO
JeffO's Avatar
great scott 1.21 jigawatts
JeffO is offline   Reply With Quote
Old 09-26-2008, 07:50 AM   #36
F.St.M.
F.St.M.'s Avatar
Originally Posted by VA Rebel View Post
F.St.M.
I usualy try to avoid licking the live lugs on the wall when I'm machining something, so enclosing them is not a concern.
Old 09-26-2008, 08:26 AM   #37
Brass Brawler
Brass Brawler's Avatar
It still amazes me that "Doc" Brown could build a time machine, but lack the necessary skills to pronounce gigawatt....
Brass Brawler is offline   Reply With Quote
Old 09-26-2008, 10:52 AM   #38
Markee
Markee's Avatar
When you build time machines at 60 years old, who has the time to learn spelling and pronunciations.
Markee is offline   Reply With Quote
Old 09-26-2008, 12:18 PM   #39
Bumpstick
Bumpstick's Avatar
My "poorman's" wheel clamp. I know, I need to turn the heat up on my welder. Hahaha...
The tried and true 'block of wood' but with channels drilled for a lil' added stability. Clamp a 2x4 to a 6x4 use a 1-3/8" bit at the seam and you get a perfect channel for the frame. 'b'
Bumpstick is offline   Reply With Quote
Old 09-26-2008, 03:11 PM   #40
buckman50
buckman50's Avatar
Im convinced Doc Brown...errr Fritz...has plans for the flux capacitor buried somewhere in his shop.
buckman50 is offline   Reply With Quote
